well that said that quickfuel makes what I want but I didnt see anything about it on the wesite.
I've been thinkin of buy a car thats got a s-trim and a blown motor.
I've got a 306 long block in the back of the garage with a forged bottom end, 185 AFR's, comp cam, studded top and bottom end with main girttle 10.5CR.
just thinking it might work well as a E85 blow threw with 7-8 lbs'ish...?
my roomate has an E-85 CSU blow-thru carb. and S-trims are good for around 500-550 rwhp. People have made more..
446RWHP and 585RWT 1998 Atlantic Blue Cobra convertible(1 of 1 built)
Vortech S-trim
346rwhp and 314rwtrq
I tell you what. You take that forged 306 and buy my whole top end heads, intake, s trim, injectors, etc and you can make 500 all day long on some leaded stuff. Smells good too. Or upgrade your lines and pump and run E85 and make 500 on that.
