Speaker wiring diagram for 83.
  • Jeffescortlx
    Frum roll
    • 2003
    I'm trying to put the radio wiring back to stock on my 83, previous owners did a good hack job and cut a lot of wires.
    Right now the problem is the rear speakers (pink/green wires). The wires are cut some where between the speakers and dash.
    Was there any factory amps use in 83?
    I cant find the speaker wiring diagram in the internetz for 83-84.
  • SDK
    #1McMoppoFan
    • 12342
    Run new ones.
    • Jeffescortlx
      Frum roll
      • 2003
      Originally posted by SDK View Post
      Run new ones.
      I'm trying to get the wiring back to stock. I want to fix the wires that are allready there. Old owner had some walmart wires ran all over the place and looked like complete shit. I want to get it as close to factoy as possible.
      • SDK
        #1McMoppoFan
        • 12342
        Right on. But if the rear wires wires are not at the dash then you will have to either splice then somewhere or run new ones. Just run the new ones where the old ones were. Only takes an hour to remove some panels and do it right.
        I'm not sure about the 83 but on my 1990 there were 2 sets of plugs in at the dash. Only one set went to the speakers.
        • Jeffescortlx
          Frum roll
          • 2003
          The plug for the speakers (or at least a plug with four of the same color wires) is still at the dash. New speakers are installed at the rear, using the factory wiring. But when I send power to the dash plug, it does'nt make it to the speakers.
          So, I dont know if there is a plug in between maybe for a factoy amp or somthing.
          I'd like to knew if the color of wires get changed from front to back.
            I don't think the color changes.
            Look behind the kick panels for the wires. They go there before the wrapped harness that heads to the trunk of the car.
            • merkerguitars
              FML
              • Jun 2007
              • 665
              I know at foureyedpride forums they have the entire wiring diagrams...
              Since I'm bored, here is the link http://www.mc-machine.com/wiring_pdfs/1983.pdf
              • Jeffescortlx
                Frum roll
                • 2003
                I found this:
                1983 Ford Mustang Car Radio Installation Guide
                Car Radio Battery Constant 12v+ Wire: Light Green/Green
                Car Radio Accessory Switched 12v+ Wire: Yellow/Black
                Car Radio Ground Wire: Chassis
                Car Radio Illumination Wire: Blue/Brown
                Car Stereo Dimmer Wire: N/A
                Car Stereo Antenna Trigger Wire: Orange/Blue
                Car Stereo Amp Trigger Wire: N/A
                Car Stereo Amplifier Location: N/A
                Car Audio Front Speakers Size: 3 1/2″
                Car Audio Front Speakers Location: Dash
                Left Front Speaker Positive Wire (+): Green
                Left Front Speaker Negative Wire (-): Black/White
                Right Front Speaker Positive Wire (+): White/Red
                Right Front Speaker Negative Wire (-): Black/White
                Car Audio Rear Speakers Size: 6″ x 9″
                Car Audio Rear Speakers Location: Rear Deck
                Left Rear Speaker Positive Wire (+): Pink/Red
                Left Rear Speaker Negative Wire (-): Pink/Blue
                Right Rear Speaker Positive Wire (+): Pink/Blue
                Right Rear Speaker Negative Wire (-): Green/Red
                So, yes indeed the color stay's the same.
                Time to pull panels and see what's up.
                • Jeffescortlx
                  Frum roll
                  • 2003
                  That drawing show's an amp.
                  And my dash does say "premium sound".
                  Ok, now where is the amp hidden?
                  • merkerguitars
                    FML
                    • Jun 2007
                    • 665
                    I believe they where hidden underneath the center speaker in the dash....
                    • Jeffescortlx
                      Frum roll
                      • 2003
                      Found the problem!
                      Harness was cut right at the drivers side kick panel. Connected it back up and works.
                      Thanks for the tips!
                      • Jeffescortlx
                        Frum roll
                        • 2003
                        ah crap, front speakers share a common wire, my deck is'nt gonna like that.
                        • matejcekautoworks
                          • 569
                          why in the heck do you want the wires to be STOCK? wuts the big deal about stock and wut, its just all gonna be covered...
                          Go Big or Go Home
                          got married, still broke lol
                          • Jeffescortlx
                            Frum roll
                            • 2003
                            There's nothen I hate more then a hack wiring job. I dont even like to buy or try to repair car's that have fucking wire nut's and lamp cords running and hanging all over the place.
                            Now, all the wiring is the way it left the factoy, clean and mathes all the OEM wiring drawings. The only thing different now is, I had to split the front speaker ground wires about 5 inches from the radio harness so it would work with a aftermarket deck.
                            All the stock wiring was still there, just needed to be hooked back up and old slop job pulled out.
                            • matejcekautoworks
                              • 569
                              i understand, but why did it have to be STOCK why not pull the old wire out and install new wire, YOUR way, cause then you know its right and if its not, its only your fault lol, JMO
                              Go Big or Go Home
