holley q's
  • 64fairlane
    • May 2026
    holley q's
    What would cause the rear squirter to not have much pump. Float level is good and diaprahm is not leaking?
  • Max Power
    • 13086
    Is it clean? Is it causing driveability problems? Pump diaphragm torn? Chamber not filling? It's a simple circuit.....
      The check ball in the squirter body can get stuck if the carb has been sitting.
        slack in the linkage?
        • mark_eych
          • 1442
          There are 30 and 50cc pumps, many cam profiles, and and nozzle size. Any of the three can change it.
          • Pauly
            It's Gone!
            • Jun 2007
            • 2870
            What do you mean by not much pump. Volume seems low, pressure of squirt is low,
            • steve vermeer
              • Oct 2004
              • 148
              worn out actuator cam causing little or no stroke on the pump
                figured it out used the wrong gasket under the squirter when i changed it and it was restricting flow thanks everybody.
