electrical problem
  • brian5809
    • 302
    electrical problem
    its a 1999 taurus,turn signals dont work,power windows dont work,interior light dont work,speedometer dont work,trunk release dont work,and power mirrors dont work.car starts and drives fine.the tach works same with fuel and water gauge all work.what could this be?already replaced a interior relay which did not do anything.
    Check fuses?
    • brian5809
      • 302
      yea,checked all the fuses
      • SDK
        #1McMoppoFan
        • 12342
        There will be multiple fuse locations on there. Or there may be a large connection on or near the interior interior fuse block that got loose
          Ground strap corroded?
          • Chrm97PI
            268ponies with more onthe way
            • 3413
            ummm, its a taurus
              Sounds like a complete failure of the internal lights.
              Ill bet there is a relay or 2 under hood that controls some/most or all of the above.
              • mg72
                All Hondas All the Time
                • 1955
                All youse is wrong. There is a body control module that is at the drivers kick near the fuse panel. You'll need to get the model numbers off of it to be able to replace it, as they are specific to the vehicle. Couple hundy and the dealer. Ebay and car-part.com should be much cheaper.
                The Jimmy hat is off.
                • allstock93gt
                  does not visit often!
                  • 1959
                  if I remember correctly there was an ssm on those cars with multiple issues. I believe it had to do with water getting into the connector on the prndl switch on the tranny. I just looked on the ford web site but with your vin # its hard to tell if it open for this car and year.
                    Doesn't you know how to use "doesn't"?
                      I'll second the BCM
                      • brian5809
                        • 302
                        prick
                        • flygirl
                          Flygirl
                          • Jun 2007
                          • 30
                          Electrical Problem
                          If you don't mind a ride to St. Paul, go to Schelen Gray Auto Electric on Snelling near I-94. When I was having electrical problems that no one could find on my mustang, I asked mustang members for ideas and this was one of them. I had multiple problems that these guys were able to fix.
                          • siberianmist
                            • 2681
                            when i was 17 i took my cadillac there a few times, overpriced dump if you ask me. i cant get half the tail lights working on my mercury i might have to take it there, im scared.
                            • brian5809
                              • 302
                              mg72 there is 3 body control modules,a brown one,a black and grey,which one?
