Which heads accept stock 5.0 pistons?
  • 1989MustangGT
    • Jul 2007
    • 798
    Since I was sold bad heads I am forced to find new ones. In searching I see many heads come with 2.02 intake valves. Is Trick flow the only ones that work with the stock pistons? Or do Edelbrock, AFR, etc.. Also work? Thanks.
    ________
    SILVER SURFER REVIEW
    afr will work. all heads will depend on your cam selection also.
    • 1989MustangGT
      • Jul 2007
      • 798
      The cam I am running is a TFS stage 1.
      ________
      Chrysler sebring (coupe) history
        you should be fine with most heads, never a bad idea to check but i wouldn't worry much.
        • five0@minot.com
          • 492
          I'm running a stock 93 short block, trick flow stage 1 cam, 58cc AFR 165's, & Scorpion 1.7 RR's, with no clearance problems. Another combo from my son's 90 LX, stock 90 short block, Comp XE 264 cam(.544 w/1.7 RR's) and Edelbrock Performer 1.90/1.60 heads. I've also ran a stock short block with Trick Flow TW heads & TF stage 1 cam. I did have to have my pistons notched with AFR 185's & an X303 cam though. Just some of my experances.
          89 LX Hatch, DART 363,C4, 88mm turbo,ms3 Pro
          86 GT
          86 LX
          82 Capri RS
          72 Demon 340 4-speed
          72 Duster 340 4-speed
          73 Dart Sport 340, 410ci bracket racer.
            That sucks to hear about your heads, but if you end up going the used route and find something up in the cities I can pick em up for ya as I frequent between the cities and mankato weekly
            • 1989MustangGT
              • Jul 2007
              • 798
              Hey thanks I will let you know.
              Also I know 1.90 valves will clear I am asking about the 2.02 valved heads.
              ________
              MAZDA PORTER PICTURE
                TFS twisted wedge work with stock pistons. I can't remember what cam you are running, but I know a few people that are running a TFS stang 1 cam with the TW heads without issue.
                Like always, you should clay the pistons to check piston to valve clearance.
