fuel pressure!
  • RedStal95
    Genius
    • 1336
    fuel pressure!
    I am putting on my 80mm maf and 30lb injectors (thanks ron)...
    What should I set my fp at?
    mod list:
    125hp dry shot (w/o shim), f303 cam, ported cobra mani, headers, pullies, h pipe...
    thanks!
    edit: 38psi seems about right for NA, but what should I set it to when I get to the track tomorrow and I'm going to use nitrous?
    Andy
    Stock 95 GT **SOLD**
    http://www.maperformance.com
    -B-S-M-
    andy, are you talking 38psi with or with out vacuum?
    i would run around 45psi with vac off or even a little more to make sure you have enough fuel getting dumped in when you spray.
    • RedStal95
      Genius
      • 1336
      w/o vacuum
      you dont think 45 would be too high?
      Andy
      -B-S-M-
        well 45 with vac off is 39 with vacuum on. so no i don't think it would be to high. just play around with it a bit and see what you can get out of it.
        • -D
          eat shit..eat my shit
          • 2708
          mine is set at 41 vac on..i need to bump it up to about 50...that doesnt help you much...but gives a guesstimate
          • wiplash
            2014 TT/GT
            • 3479
            I think you should do what Macs Stang suggests for the first run, then try 47 psi one run and 43psi the next run and compare your mph.
            -No one ever
              start with a higher pressure. say 45-50. then check your plugs.. adjust accordingly.
              this is while running the n20
