Are aftermarket shifters hard to install?
  • 91GTstroked
    • 1893
    Right now my stang has a hurst short throw, but it seems a lil out dated than some others on the market. I'm looking at the MGW shifter. I've never installed one, does anyone have this one, and if so does it come with good instructions? I've heard to use RTV instead of a gasket, anymore info would be great
  • 5.0stang85
    Hater's be hatin'
    • 7065
    do you have a t-5? well either way it dont matter it should be relatively easy to with the trans in the car. the only real trouble i had was the 2 rear shifter bolts (under the floor/tunnel). and the stop studs in the shifter may not fit in the stock console(idk for sure)?? but mine dont so just fyi
    i have a billet aluminum fidanza shifter and the stop studs on the front and back didnt really fit in the console/floor (i notched the console under the boot and it seemed to work but i liked it w/o them so they arent in it). mine is like a upto 50% reduction or something like that.
    EDIT: make sure you replace the shifter bushing in the trans you could probably get it at tousley or AV ford pretty cheap
    Cooter's Coatings
    Hudson WI
    • 91GTstroked
      • 1893
      Thanks for the prompt reply, mine is a stock T-5
      • BigMatt
        Puts that shit on everything!
        • Aug 2006
        • 4009
        Are you saying you removed the stop studs? If so thats one of the biggest advantages of an aftermarket shifter it protects your trans forks from overshifting IIRC
        But yes with very little mechanical ability you will be able to install the shifter regardles of who makes it.
          • VELOCITY
            Pacer's RULE!!!
            • 2900
            I've installed a Steeda Tri-Ax in my buddies Fox. Easy, took maybe 30min. Not quite as easy as the sn-95/new edge cars as they have alittle more room, but still it's a cake walk. I used black RTV instead of a gasket.
              87mustangguy306 is a fucking moron. Why would you remove the shifter stops and completely negate the whole purpose of a soorrt shifter?
              • 5.0stang85
                Hater's be hatin'
                • 7065
                i have a billet aluminum 3/4 shift fork im not to worried about bending/breaking it and i dont slam gears like most people do when they break them... but yes i removed them they dont fit with the poly bushings i have everywhere right now. but i have to rip my interior apart to put the heater core in it so ill probably notch the floor for them..
                Cooter's Coatings
                Hudson WI
                • 5.0stang85
                  Hater's be hatin'
                  • 7065
                  haha your fuckin hilarious kid!
                  Cooter's Coatings
                  Hudson WI
                  • BigMatt
                    • Aug 2006
                    • 4009
                    Where do you have poly bushings that interfere with the shifter Sure its not your huge donkey dick shift knob Its still a t5 anything you can do to help it last the better but thats just my opinion
                    • 5.0stang85
                      Hater's be hatin'
                      • 7065
                      i have a hyper flex kit in my car EVERYTHING is red poly. the X member and trans mount pushed the trans up about a 1/2" higher. my shifter came with studs also which are longer than bolts so its about 1/4" from the floor. i had to use a floor jack and a BFH to get my X member to just go in the mounts.
                      EDIT: i also installed my shifter before the engine/trans combo went back in the car which made it 100% easier
                      Cooter's Coatings
                      Hudson WI
                        that explains the $17k
                        • 5.0stang85
                          Hater's be hatin'
                          • 7065
                          well a hyper flex kit + ball joint and tie rod boots cause they dont come with for a 87-93 mustang is around $350 thru MAS (where i got mine cause no one on ebay had one in red)
                          Cooter's Coatings
                          Hudson WI
                            did dirty sell u that or uncle nuts?
                            • 5.0stang85
                              Hater's be hatin'
                              • 7065
                              an older guy that lives like 3 miles from me idk if he works there still or not i havent been down there since last summer
                              Cooter's Coatings
                              Hudson WI
