I have been having a lot of trouble with my fog lamps. It seems that one will go out within a few weeks of being replaced and it has happened to both. Has anyone else dealt with this? Is this something that's easy to fix?
Fog Lamp Frustration
You're not touching the bulbs when you put them in, are you? Also look for any chips/cracks in the lenses, and if there's a seal or gasket in between the lens and the assembly, check it for wear.'96 Impala SS #21,559 of 41,934
Originally posted by OutrunYou should write books. Your attention to detail had me on the edge of my seat the whole time. I had no idea what to expect until I got to the end. And let me tell you, I came. Hard. Thanks! Will read again. Asset to TCS. A++++++++++R.I.P. Rockin'98!Originally posted by SVT5LITERI had to unexpectedly part with a pair of briefs today, lol. Not totally sure what that was about
I used to go threw bulbs too. I think I must get a little water in mine when it rains. My solution was just not to use them in damp conditions and I have not burnt one out in a long time. This works for me because I don't drive in wet conditions much.--Tony--
Bones94stang@yahoo.com
94 GT, Vortech S-Trim, AFR 165's, BBK Longtubes, 1.7 Trickflow RR, Edelbrock RPM Intake, 42 # Injectors, 80mm Pro-M, MSD-BTM, 255 lph Fuel Pump, T-rex inline pump, 3:73 Gears, QA1 coil overs, and a bunch of other stuff.
1.96 60' 12.57 @113.53 MPH on Nitto's
RWHP 388.1 @5800 W/stock cam
RWTQ 386.1 Dyno Graph
That makes sense to not use them in the damp weather. I don't touch the bulbs for sure. I really prefer the way the car looks when they're on, but since it's my daily driver and I'm in the bad weather all the time, I might need to just start turning them off more. Thanks.
