sn95 master cylinder question
  • merkerguitars
    FML
    • Jun 2007
    • 665
    Ok, I'm converting my 84 Mustang to SN95 Brakes and planning on using a 95 GT Master Cylinder and the Booster....Which port on the MC is for the front brakes and which one is for the rear brakes.
    You do realize that a 85 Lincoln Towncar Master will bolt right up to the SAE threads right? It uses a 1" bore which is about ideal.
    The SN95 BB works just fine with that.
    But if you want to use the SN95, I would imagine that the front of the MC, the larger part is for the front and the smaller part is for the rear.
    • Steve
      eMechanic
      • 5381
      Rear port = front brakes
      • merkerguitars
        FML
        • Jun 2007
        • 665
        I gutted the hell out of my brake lines and decided to start fresh. The old lines where pretty gnarly.
        • 5.0stang85
          Hater's be hatin'
          • 7065
          good luck trying to find a prop valve i cant find one for S**T(if your using the factory prop valve as i would like to..)
          Cooter's Coatings
          Hudson WI
            You shouldn't use a SN95 prop valve anyways. Just get an adjustable and gut your stock prop valve. It takes about 5 minutes to dial in an adjustable.
            • 5.0stang85
              Hater's be hatin'
              • 7065
              true i have just been having trouble getting fluid to the rear lines w/ my prop valve thats why i say the sn95 valve.
              Cooter's Coatings
              Hudson WI
                Did you gut the stock valve?
