I bought this 1969 351W for a few bucks since it was a great deal. I have been kicking around the idea of a 408 but also want to explore the option of building it up for the race class I will be moving into in the near future. Instead of going with C3 heads and such
Here's the rules...
9.5 lbs per rw horsepower
9.0 lbs per rw torks
Car will weigh 3050 or so with driver and a full tank
This means I can run 321 rwhp and 338 rwtks
Using a 15% drivetrain loss through a T5 and 8.8 --> 369 fwhp, 388 fwtorks
Any aluminum heads
Any type of cam
Any ignition
Any intake
Any exhaust
Obviously it won't take much to get there with a 351. I may need 6300 revs to keep the gearing I have.
What parts do you recommend?
Use the stock crank?
Eagle SIR I beam rods?
Which heads to make this power level? TFS too much?
Which intake?
Which carb?
Which cam?
Should I go with any block mods (ie girdle, 4 bolt mains)?
Here's the rules...
Any aluminum heads
Any type of cam
Any ignition
Any intake
Any exhaust
Which intake?
Which carb?
Which cam?
if you get caught.
Probably going to be illegal in the near future. There are LS1 foxes in the class right now.
If you want a 500hp 393, or a 408 rotating assembly let me know.
