Bad Gas Mileage. Why?
    After taking my 86 out of storage for the first time this year, I have noticed a decrease in mileage. I get about 120-140 miles per tank of gas. I used to get about 200-220 if I was being nice and easy. I still drive it easy, and I can almost watch the gauge go down as I drive. I do not have any leaks at all. After I did all of the swapping, I still got a decent amount, about 200. I changed the plugs, plug wires, cap, rotor and coil. I do have the fuel pressure jacked up a bit, I cannot remember the exact specs, but it is not too radical to max out the injectors. I ran an OBD II on my car and no trouble codes came up. I thought maybe the O2 sensors might be shot but according to this, they are fine. What else would cause my mileage to go way down?
    Engine Modifications:
    1986 Ford Mustang GT
    -Ford E7 Cylinder Heads, Ported and polished with a 5 angle valve job, and Performance Vassco Dual Springs, Moley Keepers and Retainers
    -Ported Lower Intake Manifold off of a 1986 Mustang 5.0
    -Upper Intake off of a 1993 Ford Mustang 5.0
    -Mass Air Conversion
    -1/5/8 Jet-Hot Coated Pacesetter Headers
    -Kirban Adjustable Fuel Pressure Regulator
    -Pacesetter Off Road H-Pipe
    -Flowmaster 3 Chamber Exhaust
    -65mm Ford Racing Performance Throttle Body and EGR Spacer
    -3.55 Rear End Gears
    -19 Pound Fuel Injectors
    -Ford Motorport 9mm Spark Plug Wires
    -MSD Blaster Coil
    -Modine 3 Row Radiator
    -180 Degree Thermostat
    -Pro 5.0 Power Tower Shifter
    -140 Amp Powermaster Alternator
    -K&N Conical Air Filter
    -ARP Head Bolts
    Suspension Modifications:
    -Tru-Speed Strut Tower Brace
    -Tru-Speed Shock Tower Brace
    -KYB Gas-a-Just Shocks, Struts and Quad Shocks
    -Subframe Connectors
    -Steeda K-Member Brace
    -Eibach Lowering Springs
    -5 Lug Conversion Which Includes 11” Front Rotors with Dual Piston PBR Calipers and Rear Disc Brakes
    -1999 Ford Mustang Cobra 17” Wheels with Yokohama AVS/ES100 245/45/17 Rubber
    - Maximum Motorsports Caster/Camber Plates
  • I Tried
    Pull my Winch Line 4 Me.
    • 6103
    How hi is your fuel psi and what did the plugs look like ?
    • lilstang5O
      • 9204
      smell any gas out the pipes? if so bad pressure regulator or its adjusted lil high??
      Ride:
        Chect the fuel pressure or the regulator. My guess would be there.
