low rpm shuddder
  • horseplay2
    • 125
    low rpm shuddder
    when i am driving, right around 15-1800 rpm, when i am excellerating i get a shudder in the front and feel it through the dash... is that u-joints, or possibly a lock-up converter? any ideas fellas? thanks Brian
    1990 lx coupe, 331inch, E-85 conversion
    270 RWHP-320 RWTQ, comming soon, 86 4eye conversion
  • lasered
    • 1773
    this is in the notch right? all speeds within that rpm range?
    Originally posted by Fosters
    My mustang is powered by Chuck Norris and runs on baby tears.
    • horseplay2
      • 125
      sorry, this is in my 93 gmc sierra 4x4....
        converter
        • lasered
          • 1773
          converter
          that would be my quess
          • horseplay2
            • 125
            is there a way i can disconnect that?
            • lasered
              • 1773
                You can test it by taking the trans out of overdrive and running it in D3. This will prevent the lockup feature and should eliminate the problem. Put in some Seafoam trans tune, run it, then change fluid in a few hundred miles.
                • lasered
                  • 1773
                  there are "band-aids" such as the one 68GTO said but the problem will continually get worse over time. If your converter is even the problem
                    Well, that is not my experience. Perhaps the converter is gummed up. I did this procedure to my AT over 100K ago and it has not since made this shuddering.
