Driveshaft Removal Help
  • 93stang351w
    a notch fox
    • 179
    trying to remove the drive shaft.... i have the tranny out so the slip yoke end is out but i cant get the other side off... I bolted off the 4 drive shaft bolts that connect to the rear end but it still wont come off....do i have to take off the ujoint?? cuz that will be a bitch.... do i need a special tool to take the u joint off??? please help!
  • bbredstang
    • 161
    once you have the four bolts out at the rear end.....put a floor jack under the pumpkin and jack it up. Eventually it will create slack and let you drop the driveshaft under the pumpkin...once there you will be able to slide it out of the tranny.
    hope this helps
    • I Tried
      Pull my Winch Line 4 Me.
      • 6103
      Hit it with a hammer
      • Mustangmatt
        The bobs...
        • 10806
        Yeah push the yoke back in towards the tranny, you went the wrong way
        Tech Tip-
        A smart idea would be to get a junkyard yoke and put it in, that way there isn't tranny fluid everywhere when you tip it around
        • DNeinstadt
          Administrator
          • 12578
          You guys dind't read. He has the tranny out.
          You could do I TRied's idea about the hammer. It's probably just rusted on the rear end.
          Dan
          • zakstang
            Mustang Fanatic
            • 479
            "when all else fails, use a bigger hammer or more duct tape" sound advise i got once from an old wise man.........
            It is not the critic who counts,the credit belongs to the man who is actually in the arena,whose face is marred by dust and sweat and blood,who strives valiantly,who knows the great enthusiasms,the great devotions,who spends himself for a worthy cause; who,at the best,knows,in the end,the triumph of high achievement,and who,at worst,if he fails,at least he fails while daring greatly,so that his place shall never be with those cold and timid souls who knew neither victory nor defeat.
            • #7
              Spray it with some wd-40 and let it sit over night then try to knock it loose?
              • Wheelspin
                Faster, Cheaper
                • 216
                Just did this.
                Spray with WD or Knock'er'Loose. Grab propane torch and heat the piss out of it. Spray again with WD or Knock'er'loose. (It will smoke and stink, but won't burn.) This cools it, and "wicks" the penetrant into the gaps. Then nail it with a hammer. It should come right off. (This trick works great on stuck bolts too, especially if you can hit just the bolt and cool it faster than the surrounding material.)
                "On a scale of one to great, I'm.... SUPER AWESOME!"
                -SB
                "Ah, beer, my one weakness. My Achille's heel, if you will."
                "All right, brain. You don't like me and I don't like you, but let's just do this and I can get back to killing you with beer."
                --Homer Simpson
                • 93stang351w
                  a notch fox
                  • 179
                  thanks for the advice.....didnt have a propane torch but i used a flat head screw driver and wedged it in with a hammer and pryed it off.....finally i got that off then 5 minutes later i was putting tranny mounts on my new tranny and there was a little rust on the tranny mounting hole threads so it was hard to tighted the mounts on the tranny....so i was tightening one side (very hard to tighten because of rust) and i herd a crack.... the whole part of the tranny where one of the mounting holes was located just snapped off.....im pissed and i dont know what to do....ill make a thread about this
                  • Wheelspin
                    Faster, Cheaper
                    • 216
                    Have it welded.
                    -SB
                    --Homer Simpson
