Bad weekend on the wrench... explorer/kaw. help...
  • dviskoe
    Bullitt2364
    • 326
    OK,
    So, my '93 explorer's driver side door hinges are shot, when I goto close the door, I have to lift up on the thing to get it to close. looking at the hinge, there's a little piece of (!@#$%^&*ing) plastic bushing that has worn out on both upper and lower hinges.
    SO, I goto take the (!@#$%^&*ing) thing off, and they have 3 bolts ...
    (wait for it ...)
    and there's a (!@#$%^&*ing) RIVET, with a head the size ofa quarter...
    So, if I do drill it out, pound it out or whatever, how would I get the junkyard ones back on ??
    Then if that weren't bad enough,
    taking the front tire off on my kawie, ZRX1200, the right side is a 22MM allen, the left 17MM
    ARRG...
    so I cobble together some bolts for $5 (the snap-on 22MM is a $40 purchase) but cannot get the (!@#$%^&*ing) thing off, it's tighter than a ... well, you know.
    anyway, sorry for the rant, but if anyone has an idea or two, that would be great.
    '01 Bullitt #2364 RWHP 242 RWT 277 Dr. Gas X-Pipe K&N FilterChargerHi-Tech tune (thanks guys !) 4.10 gears
  • POOPY PANTS FACE
    EAT SLEEP POOP
    • May 2007
    • 12400
    drink more beer pass out and work on it tomarow
    TCS auto ftl
    • lasered
      • 1773
      Originally posted by Fosters
      My mustang is powered by Chuck Norris and runs on baby tears.
        Why not just pull the pins and replace?
        • 1989MustangGT
          • Jul 2007
          • 798
          Pull pins if possible. Use heat on the nut to get off.
          ________
          Star craft replays
          • dviskoe
            Bullitt2364
            • 326
            the hinge pins u mean, right ?
            y, they're not designed to come out either, flanges on both sides
            Right now the door is completely unbolted, jus kind of set back on... I should put a $5 in the drivers side seat, lock all the door and wait for someone to try to take it...
            ... better yet, leave the keys in the thing and hope someone does take it
            • allstock93gt
              does not visit often!
              • 1959
              put new hinge pins kits in. they come with bushings and pins. you can buy them from any ford dealer. they are like 5 bucks each. and no need to unbolt the hinges.
                what I was getting at.
                • mstngmikegt
                  • Jan 2007
                  • 276
                  Haven't done your particular rig, but typically there is enough room to get at the pins with a sawzall...just cut em in half and drive out both ends...so much for the flanges (a long reg screwdriver works good to drive into the cut and spread them so you can get ahold of em at the top and work em out). If space is too tight for the saw, a short hacksaw blade on a handle works too. Many auto parts stores/Sears, etc sell these. Works, just more muscle involved. Spare hands and support for the door will be a good thing here too, btw.
                  • 88mark8
                    • 344
                    i have the tool for you bike wheel. i got it at bobs cycle in st paul for about 25$.
                    i have the steel one
                    http://www.bobscycle.com/browse.cfm/4,61345.html
                    • xcsboost
                      Got Oil Bitches
                      • 2810
                      Originally posted by dviskoe View Post
                      OK,
                      (wait for it ...)
                      ARRG...
                      i have a 28volt impact that'll get that fucker off for ya
                      • dviskoe
                        Bullitt2364
                        • 326
                        I shouldda thought of Bob's, it's right across the road from me , that looks like exactly what I need ...
                        I got a 'rebuild kit' from tously ... forgot to ask for the cool guy discount, $35 for 2 pins and 4 bushings, oh well, I've a die grinder I gonna take to the thing, 1 down, one to go,
                        Thanks fer yer suggestions all,
