Starting problems
  • shoey11
    • Dec 2007
    • 29
    Starting problems
    A few weeks ago i told you about my starting issues with just the key selected on, when i push in the clutch the starter cranks. I still have this problem. Ive read about some fuseable link that could be my problem? I keep thinking GROUNDING issues? I think i have checked everything but obviously not! I installed a mini starter along with a new engine install, followed the directions properly, but i am frustrated beyond limits now. I also noticed that I have power on both terminals to my coil? Could be related or not? Ground problems? Thanks.
  • XJHEAD
    • 718
    Sounds like the key switch is fubar.. You have the battery going to the original spot on the (stock)solenoid, new (large) cable from same point to the starter, small (12 guage) on (stock) solenoid opposite side from the two large cables and the factory small wire to the side of the factory solenoid right. If so, when key is on it is energizing the feed wire via the clutch switch. Bad ign. switch
    7.64 @ 187
    K/S K
    3400 lbs.
    DynotuneUSA
    • Pauly
      It's Gone!
      • Jun 2007
      • 2870
      I am not sure how it works but do you have to push in the clutch to make the car start? If yes my guess is a wire got switch with the install and you are either feeding the starter current when you push the clutch in or completeing a ground. Sound to me like a wire was not installed correctly. I would take a break then recheck your wiring for clutch swith to selinoid and etc. good luck.
      • shoey11
        • Dec 2007
        • 29
        thats how i hooked it up as you discribed, I will check the switch out. thanks
        • shoey11
          • Dec 2007
          • 29
          Its seems to simple to hook up my solinoid wrong? Its just as the directions state to do with the mini starter install, Thanks for the feedback, I will check it out carefully again.
          • svonasek
            • 1641
            Is this on a fox body? Have done anything else lately besides the starter?
            I'd start by pulling the plastic off the underside of the steering column and checking for voltage at the ignition switch connector. It a white wire with either a blue or pink tracer (I can't remember off the top of my head). You should only have power there with the key in the start position
            If you have power there disconnect the connector and see if you still have power on the wire. If you don't have power with it disconnected then you have a bad ignition switch. If you still have power then I'd take a look underneath the car at the connectors at the transmission and the harness coming off the body to the transmission. Those can get pretty close to the exhaust and could have melted a couple of wires
            • XJHEAD
              • 718
              Originally posted by shoey11 View Post
              As soon as i push in the clutch with the key just in the on position, the starter cranks, when i select the key to start it stops the starter.
              That is the reason I think it is his switch is that in his other post he states that, when in RUN position clutch in it starts, but will not when in start position.
              7.64 @ 187
              K/S K
              3400 lbs.
              DynotuneUSA
              • shoey11
                • Dec 2007
                • 29
                You might have something there, those wires that go to my tranny are shot. they look like hell. I will check the switch out also, thanks for the help
                • svonasek
                  • 1641
                  Did you ever get this figured out?
                  • shoey11
                    • Dec 2007
                    • 29
                    I havent had the time to look at it yet, I have the next few days off after today so I will let you know, or ask for more help then.
                    • shoey11
                      • Dec 2007
                      • 29
                      Got it, I went right to the wires that hook up to the reverse switch on the tranny, and sure enough, wires were chaffed together, repaired them and good to go! I never would have thought to check there for a starting problem! You rock svonasek! thank you all for the help!
