Oil Pressure Questions...
    At Normal Operating temp, what would a good pressure be for a 302 based motor?
    What would consists of Normal..
    How about under load/Normal driving?
    Just curious... i have been beating the shit out of the motor in the II for the last 3 years and its holding up quite nicely... Or so i think...
    50 lbs when cold @ idle
    25 lbs when warm @ idle
    50ish lbs when normal driving (2500 ish rpm, 5th gear on the freeway).
    I Think this is good, but, i've blown my share of motors...
    10 psi per 1000 rpms
      So... at 3k.... 50psi is good...
      at 1k rpm its around 25...
        yea thats good seen way worse run a long time
        • Steve
          eMechanic
          • 5381
          You're fine with those numbers. Pretty healthy. My old engine used to have 10psi @ idle when hot. It never blew up but after I twisted off the pump shaft, I built the new one. My new one shows 40 psi @ idle when the oil is @ 200 degrees. I imagine it will be down to 25 or so when I get the oil up to 260-280 degrees.
          • D3thM3tal
            IT Pro / Mechanic
            • 3665
            I'll post a picture of my junk tonight - at operating temp the gauge reads around 70psi..
            I bleed blue
              The gauge is from the 70's!!!
              • D3thM3tal
                IT Pro / Mechanic
                • 3665
                Yeah - I'm a little skeptical...
                I bleed blue
                  The motor is good tho
                  • D3thM3tal
                    IT Pro / Mechanic
                    • 3665
                    Indeed - it sure would run a hell of alot better with a new accelerator pump! Can only get them in a rebuild kit - it just runs so damn good I kinda don't want to mess with it...
                    I bleed blue
                    • c10
                      • Dec 2006
                      • 1521
                      I wouldnt worry about it at all that sounds pretty good. I had a 302 with unknown miles that has about 10lbs warm at idle and like 40 lbs cold at idle. I pounded the shit out of that car and now my brother has that motor in his mustang
