I did some engine work on my 91 5.0 it seems to be eating through a lot of gas. gas smell in the exhaust is also pretty pungent. Where's a good shop to get a little tune? not looking to spend hundreds on dyno tuning or anything, just a little tweaking.
91 mustang tune
Problem is that it changes your a/f ratio EVERYWHERE, not just at WOT. To correct the a/f mixture by changing fuel pressure you could be causing your part throttle a/f to go beyond what the fuel trims can compensate for. Possibly causing drivability issues, as well as poor fuel economy. Not too add the fuel pressure is a linear change. If your rich at 3500rpm, and lean at 5000rpm, bringing fuel pressure up to fix the lean conditions at 5000, is just going to make it richer at 3500rpm. Vice versa, bringing pressure down at 3500rpm to lean it out is just going to make it leaner at 5000rpm.Originally posted by mnstang View Postwell you have a fuel pressure regulator, but you need an adjustable one to adjust the fuel pressure, which in turn changes your a/f ratio.
you can probably get by right now with stock injectors. if you swapped you wouldn't need a tune.
I agree with paying to get a baseline on it, cause it may not need any changes at all. The A9L/A9P computers are pretty damn good for keeping a decent a/f even after mods. Usually if they go lean its because of a faulty MAF, or other non computer related issues.
But if it is off....
An adjustable fuel pressure regulator was the way to do it back when there simply just wasnt much around for tuning software. But why spend $100 on a fuel pressure regulator, and then another $50+ on dyno time just crossing your fingers that its right. Save the money and do it right the first time.I send myself PM's so I roll with a full inbox! Sweet35th style!
I suggest you get it baselined, simply to see where you are at and if it needs a tune. If it does need a tune, then yes the stock computer can be programmed.Originally posted by loudexhaust View Postso are you suggesting getting a custom chip? If I brought it to get dynoed can the stock computer be programmed?
I know you said earlier that it seems to be eating lots of fuel, and the exhaust smell is strong. I assume you do not have cats? The exhaust smell is always stronger when there are no cats on the vehicle. As far as eating lots of fuel, what do you have your base timing set to?I send myself PM's so I roll with a full inbox! Sweet35th style!
i know it's not the perfect solution or as good as a custom tune, but it can help and it sounded like he didn't want to pay 500+ for a tune.Originally posted by Sweet35th View PostProblem is that it changes your a/f ratio EVERYWHERE, not just at WOT. To correct the a/f mixture by changing fuel pressure you could be causing your part throttle a/f to go beyond what the fuel trims can compensate for. Possibly causing drivability issues, as well as poor fuel economy. Not too add the fuel pressure is a linear change. If your rich at 3500rpm, and lean at 5000rpm, bringing fuel pressure up to fix the lean conditions at 5000, is just going to make it richer at 3500rpm. Vice versa, bringing pressure down at 3500rpm to lean it out is just going to make it leaner at 5000rpm.
it still can be the way for people not wanting to spend that kind of money, 500 bucks is alot of coin, especially for some of these cars that are getting old and barely worth that anyway. plus alot of custom tunes are not right the first time.
