Building a cage - Tube diameter & thickness ??
  • BOB_T
    Kounty B Kustomz
    • Dec 2006
    • 788
    I just picked up a Air assisted Bender & a Hole saw jig for cutting tubing so i would like to start fabricating a cage as soon as possible.
    Is there any particular type of tubing ( size , thickness , ect ) that I need to use in order for it to pass inspection if i wanted to go to a track ????
    Any info is appreciated & Thanks for your time , BOB_T
    351W into Fox needed:
    7qt oil pan , Billet Dizzy/Ignition , 1 7/8'' headers for TFS R heads , adjustable Tubular rear suspension & parts , Roll cage , 8+ gallon fuel cel / lines, ect..
    TFS R heads off of 420ci engine
    you could just look at the most recent rule book for NHRA
    • 2 beer
      Insurance guy
      • 21868
      NO GODDAMMIT!! ASK TCS!!!
      952-229-5130
      • nut-up
        noob...forever!!!!
        • 665
        material
        assuming a 8.50 cage 1 5/8" .083 wall CM or 1 5/8" .118 wall MS
        should work just fine. if your looking at going faster just call the sfi foundation and get their specs for it http://www.sfifoundation.com
        I'm not here to make friends, I brought my own.
        • BOB_T
          Kounty B Kustomz
          • Dec 2006
          • 788
          ^^ Thanks .................
          • nut-up
            noob...forever!!!!
            • 665
            not sure about the welding, we tig all our stuff so i dont know if they will let you wire feed anything anymore. I would call the local nhra tech guy and ask someone on here has his number, maybe they will chime in.
              Wirefeed is ok, Tig is better, just cant have any double pass welds and you can't grind down any of the welds or fix them. Must be one continuos weld.
                they will need to certify it once it's doen anyways so better to call them first before you try and build it.
                • nut-up
                  noob...forever!!!!
                  • 665
                  i just dug up my 25.5 book from sfi they say its okay to wire feed, if its okay for them then its okay for the track. from the sfi book
                  1. All structural material for the roll cage (tubing flat bar, etc)must be normalized 4130chrome-molybdenum steel (4130n) purchased to requirements of military specificationMIL-T-6763b and its subsidary documents or equivalent, or mild (carbon and alloy;seamed or seamless round;as welded hot rolled, round;mandrel drawn,round cold worked,round) steel tubing purchased to the requirements of ASTMA519 or A513.
                  steel: round tube larger than 1 1/2" nominal wall thickness .118
                  1 1/2 or smaller nominal wall is .108
