Difference in Top End Kits
  • SweetLou
    Resident Phatass
    • Apr 2008
    • 1551
    Been looking at different top end kits.
    Late Model Resto Has a new kit out featureing the GT40 heads. Power wise, what is the difference between the Trick flow, and the ones with the GT40's?
    1st kit is a Cobra Intake, GT40x Heads, and a E303 cam $2,279.95
    2nd kit is Cobra Intake, GT40p Heads, and a E303 cam $1,1649.95
    Then you have the Trick Flow Twisted Wedge top end kit which is supposed to put you up in the 350hp to 360hp range depending on which set up you get priced between $2419.95 - $2529.95. That kit includes the heads, intake, and cam as well.
    Input please, cuz I have no idea which kit to get. I want my car steetable, but nice power. And if the Late Model resto kit isn't much off in numbers from the Trick Flow, then I would prolly end up going with the LMR ones. I may look into a small blower in the future as well, prolly only about 6-8psi.
    Dont sweat the petty stuff, and dont pet the sweaty stuff
    TFS
    • lark-o
      • 10489
      Id go with the wedges, if the day ever comes where you need more head you can port the hell out of them and make some big power. gt40s are good heads but they dont compare to TW's. a cobra intake is only good for around 350hp na where a TFS intake can support over 400. just make sure you get the upgraded spring package its worth the money.
      You can save some money and buy used and piece a kit to gether for probably around $1,800. just becareful with buying used heads.
      • tittan1500
        Got Automation!!!
        • Nov 2007
        • 77
        take that $2419.95 - $2529.95. and save 500$ more and go buy a LS1 with a T56 from ebay or craigs list. you will have that power stock and have a lot of room for mods
        2000 LS1 TransAm NHRA
        3200 stall long tubes borla cat back
        Midnight blue and silver 86 Z28
        tan interior
        305 Comp Cams XE268H , Edlebrock 600cfm carb, weiand action plus intake
        Mallory ignition system
        headers with Magnaflow muffler.
        98 Z28 10 bolt
        :3gears:
        • POOPY PANTS FACE
          EAT SLEEP POOP
          • May 2007
          • 12400
          id do it if you could make it fit in my 95
          TCS auto ftl
          • lark-o
            • 10489
            • lark-o
              • 10489
              • Hack
                • 1415
                That would be a great idea if LS motors didn't suck so much.
                Just what I want to do.. spend $3k on something that someone else has worn out and used up.
                2017 Mustang GT PP
                1986 Porsche 944
                  Originally posted by MadMatt5oh View Post
                  TFS
                  no question.
                  • c10
                    • Dec 2006
                    • 1521
                    • 289Notch
                      Lowballer
                      • 7340
                      BRODIX heads + holley intake + anderson or ed curtis cam.
                      Mustangless!
                        What happened to Mr. Clever and a solid mech cam?
                        • 289Notch
                          Lowballer
                          • 7340
                          he couldn't handle it.
                          Mustangless!
                            • lark-o
                              • 10489
                              LS motors dont suck they are actually quite efficent and reliable...you just dont put one in a ford thats all.
