I know plenty of people have wired up one of these on their fox, which wire on the o2 sensor do you use?
Narrow band wiring question
either of the o2s work fine.Originally posted by orangefox View PostI know plenty of people have wired up one of these on their fox, which wire on the o2 sensor do you use?Originally posted by HackWhy spend all that money just to get a worn out copy of a small block Ford? It's going to be in the junk yard for a reason. I understand you have a religion called LS motors and you have faith that the LS motors break the laws of physics and work better and cost less than anything else ever built. Plus they never wear out.
I thought it was just a single wire for those?Originally posted by HackWhy spend all that money just to get a worn out copy of a small block Ford? It's going to be in the junk yard for a reason. I understand you have a religion called LS motors and you have faith that the LS motors break the laws of physics and work better and cost less than anything else ever built. Plus they never wear out.
