Whipple blow off/ bypass valve.
    anyone know if there is a way to adjust the blow off/bypass valve on my whipple? ive done a bunch of searching on the web and called them at whipple and wasnt able to get any info's'
    i just got my boost gauge in and its making 5psi. but unless im totally in it the boost bleeds off almost immediately like the bypass/blow off is super touchy or some shit.
  • KrisR
    KNT-SHO
    • 12737
    You should only see positive boost when you are at or very close to WOT. As soon as you let off WOT, even a little bit, your boost should drop significantly (especially if you're only making 5psi under peak boost). I'd say it sounds normal?
      maybe it is i have no idea. it just seemed odd to me
        its fine
          If you are still under vacuum then the bypass is open, bleeding off boost. I'd say it is perfectly normal mang.
          • LilRoush
            TRDon's little spoon
            • 2214
            Just unhook the vacc line from the bypass reg, ziptie the valve closed and let me know what happens.
            ~Matt
            1998 Roush M112: Aluminum block 4.6 2V T56 1 of 1 made
            1999 SVT: Daily driver, part time track car
            1970 Mach 1: Resto-modded 351W
            2000 Roush #5004: World's FIRST M112 supercharged V6 Mustang 1 fo 106 made SOLD, but not forgotten.
