Not Enough Clearance?
  • MustangManiac
    Why not?
    • Mar 2007
    • 186
    How much lb ft. should it take to turn over a crank by hand?
  • Dustball
    My title here
    • 3251
    The fresh 460 I did a few weeks ago was about 30 ft/lbs my best guess. I was able to turn it with a standard 1/2" ratchet, maybe 10" long?
    • Old Man
      Elder Statesman
      • 5711
      Just the crank, or assembled short block? Assembled short block should be about 20-25 lbs for a small block, 25-30 lbs for a big block.
      The real question is how much clearance do you have?
      www.transport-graphics.com
      www.knowltonsthunderheads.com
      www.dukesraceshop.com
      www.meanstreetperformance.com
      www.fleetwoodcollision.com
      www.idealautoglass.net
      • gutlas5
        "7718"
        • Dec 2005
        • 2656
        spin it fast enough and it'll self clearence lol
        10.89@123
        • mustang cobra93
          PROCHARGER
          • Mar 2007
          • 3964
          "The power of the RIFF compells me"
          "Champipple"
          • MustangManiac
            Why not?
            • Mar 2007
            • 186
            It's a complete 351W. Seems like when we try to start it, it wants to start but it can't. It'll crank over and almost start but it won't. We can't turn it over by hand. Any suggestions? I think we might have to completely tear it apart again.
              • Old Man
                Elder Statesman
                • 5711
                Are you are trying to turn it over by hand with the spark plugs in? If so it will be very hard to impossible.
                If it cranks, but wont start, you need to check for fuel, stark, and cam/ignition timing.
                • allstock93gt
                  does not visit often!
                  • 1959
                  if you cant crank it over buy hand with the plugs out its time to start over!
                  • MustangManiac
                    Why not?
                    • Mar 2007
                    • 186
                    we figured it out. This is our first engine build so I didn't know we had to adjust the valves. We did that and now it turns over and runs.
