How low is too low
  • 64fairlane
    • Oct 2026
    How low is too low
    For a street driven car i ask because with the springs i have now i have about 3 inches of ground clearance under my trans pan.
  • I Tried
    Pull my Winch Line 4 Me.
    • 6103
    If you can't clear a pop can you will catch man hole covers on the street form time to time.
    Ask me how I know.
      how do you catch a man hole cover?
      • I Tried
        • 6103
        My last street rod I built. The front bumper would just barley clear a pop can the front suspension cross member hung down about half a inch below the bumper. The bumper cleared a man hole cover that was sticking up in the road a bit. The cross member did not. I was doing 20-30mph. I came to a very fast stop!
        • Doug
          • 3127
          if you cant put the front of your foot under the bumper, its a tad too low
            The bmw is low. Real low, no problems yet.
              ouch, yea i wouldnt care a whole lot but it would make a big mess hitting the trans pan
                i cant put a jack under the front crossmember if that counts
                • Bill M
                  fastest inline head SB in RS/N
                  • 3404
                  I liked my cars nose on the ground, but I didn't like scrapeing the bottom on every RR tack/ speed bump. Also not being able to get a floor jack under it without people to lift up on the fenders sucks too. I wouldn't go too low. I raised mine just high enough that a jack could fit under the k member.
                  "Uh oh, that ain't good!"
                  www.meanstreetperformance.com
                  • Doug
                    • 3127
                    you're on the right track!
                      i figure ill bring it up a couple inches i guess just didnt feel like buying new front springs for the front
                      • prostang92
                        keeper of the lost toys
                        • 4479
                        64 should have seen it wit hte 2" drop spindles...
                        WWW.RACECARREVOLUTION.COM
                        WWW.TRANSPORT-GRAPHICS.COM
                        • SicLinc98
                          Sic One
                          • Sep 2005
                          • 3027
                          I ran low in my ricer. Build a skid plate
                          • HELLFYR
                            Shelby-ing
                            • 3081
                            Run it 4x4 height... no need for lowering springs
                            • GoldenPlump
                              • 6863
                              3" actual ground clearance is boarderline. My first Z had 3" ground clearance and it was a bitch. Nothing worse than HAVING to go through potholes and hearing it scrape
