Front sway bar
  • orangefox
    • 1603
    Front sway bar
    Would you run a front sway bar on a drag race only vehicle. Yes or No?
    2002 Ford Excursion
    2003 Ford Expedition
    2005 Mercury Mariner
    80' Buick Regal drag car
    88' LX Mustang 5.0
    2010 Yamaha Road Star
  • GoldenPlump
    • 6863
    I've always heard to not use the rear one on Datsun Zs as it helps the IRS plant better.
    Not sure when it comes to a solid rear end though.
    • Old Man
      Elder Statesman
      • 5711
      No
      www.transport-graphics.com
      www.knowltonsthunderheads.com
      www.dukesraceshop.com
      www.meanstreetperformance.com
      www.fleetwoodcollision.com
      www.idealautoglass.net
      • orangefox
        • 1603
        Originally posted by Old Man View Post
        No
        Reasons?
        2002 Ford Excursion
        88' LX Mustang 5.0
        • Novi2KGT
          • 1758
          Hell, mines more of a street car and I don't have one
            what happens when you dont run one? is it unsafe?
            • orangefox
              • 1603
              All I know is today was my first time without it and the front end of the car twisted like a pretzel out of the gate and finished off my left front shock. It now rests on the lower control arm rubber stop!
              2002 Ford Excursion
              88' LX Mustang 5.0
              • SDK
                #1McMoppoFan
                • 12342
                Isn't it just a wieght issue.
                • orangefox
                  • 1603
                  That is why I took it out, to save weight.
                  2002 Ford Excursion
                  88' LX Mustang 5.0
                  • SDK
                    #1McMoppoFan
                    • 12342
                    The front is supposed to sit on the springs they carry the weight. If the shock broke then get new shocks. I don't think the sway bar has much to do with caryring the weight of the car.
                    • orangefox
                      • 1603
                      I know the swaybar doesn't carry the weight of the car at all, I was more concerned with whether it actually had any benefit to body roll or what not when launching.
                      2002 Ford Excursion
                      88' LX Mustang 5.0
                        so.....whats the verdict? if you took off the front sway bar on say a 72 chevelle would it make the car unsafe handling?
                        • oriosmit
                          Making baby seals cry
                          • Jun 2007
                          • 602
                          Removing it also allows the front to rise significantly higher allowing more weight transfer to the rear.
                          Your shock broke for reasons other than the removal of the sway bar.
                          Running one in the rear however is beneficial because it helps keep the load applied evenly to both rear tires. A drag bar for instance won't give you those right rear squatting launches. With a dedicated drag bar in the rear you would not need an air bag also.
                          • Fosters
                            Typical white person
                            • 16014
                            I haven't ran one in a while. basically, makes frees up the nose of the car and lets the suspension do it's thing, without being tied to the frame of the car. I've never heard of a shock break due to no swaybar. Your car will feel more like a minivan mainly due to the same reason - since your nose can now move higher when accelerating, one side can also go higher and the other can go lower when you're cornering. It's a bit unnerving at first, but you get used to it. One thing, after (drag rate) coilovers, my car feels just as stable as it did stock, with the swaybar, and it still lifts just as much if not more now.
                            do this: remove the swaybar endlinks only, drive it around, see how bad you hate it/like it. decide whether you wanna go all the way, remove the swaybar too - that'll be the weight savings part, which alone is worth it if you ask me - 30 lbs off the front of your car is not easy to get usually...
                            • Grenade
                              • Mar 2005
                              • 3659
                              I always remove the swaybar when I'm being serious about a time. If I'm being half-assed, and trying to get a street trim time, I leave it in.
