CAR STEREO GUYS!!!!
  • taank
    • 10278
    CAR STEREO GUYS!!!!
    i have a precision power 5 channel amp that no Longer has any output. can it be repaired? where? what is it worth fixed or broken?
    Jake H.
  • xcsboost
    Got Oil Bitches
    • 2810
    junk.t
    • KRYPTO
      Our Fearless Leader
      • Sep 2007
      • 1632
      it may be worth fixing due to it being a PPI. It can be fixed it just takes time to find what part is fried. Look on there site and find dealers/repair shops.
      Im in Blaine letting some girl get 14" inches, i think she knows you....
      If you think your shit is fast, you'd think my fucking turtle is a time machine.
      Our Fearless Leader
      • 85stang
        04 GT
        • 379
        how'd you blow it??
        ??NO fuse tisk tisk.
        did you actually test the outputs and inputs of the amp with a volt meter or ohm meter?
        • taank
          • 10278
          Originally posted by 85stang View Post
          how'd you blow it??
          best buy bench tested it, no output. yes i have a fuse running 4 gauge kicker with kicker supplied fuse and dist block
          Jake H.
          • SDK
            #1McMoppoFan
            • 12342
            I had a few amps repaired along time ago. I cant remember what those things are called at the heat sinks. Anyway if they all need to be replaced it could be expensive. Big amps have several of them. They were always the problems on my amps from grounding out the speaker outputs.
            • Jeffescortlx
              Frum roll
              • 2003
              There called FET's, or MOSFET's.
              Some times when a output shorts, it takes out the power supply with it. So now 2/3 of the amp is garbage. As long long as the board is'nt burnt up to bad it can be repaired.
              I might be interested in buying it as is, or repairing it for you for a small fee. Or as least I can tell you if it's worth fixing or not.
              • xcsboost
                Got Oil Bitches
                • 2810
                send it to ppi they will fix it for u
                • POOPY PANTS FACE
                  EAT SLEEP POOP
                  • May 2007
                  • 12400
                  if its old enught it could be worth somthin..
                  TCS auto ftl
                  • worxbullitt
                    hammer down
                    • 277
                    FYI ppi is now and has been owned by Directed Electronics (dei) for some time now. if its an old school art series- they wont be able to fix it, and usually dont anymore.. there are no more parts for those amps being made and unless you get really lucky youre gonna be SOL... sometimes if ya talk really nice to the tech guys at DEI they will swap it for a new DEI amp though...
                    if youre looking for a good 5 channel to replace it with take a look at the memphis line.. good amps for the buck.
                    PS-- having no fuse on the power side doesnt stop an amp from blowing.. it only stops the car from burning down if the wire is shorted/pinched..if the amp is grounding on the speaker output side, it will be drawing more current trying to make power and that extra current draw is what blows the fuse, but it still wont protect the amp at all.. if you installed fuses on the speaker output side(1 fuse on pos, 1 on neg speaker output for each channel, that are rated for slightly higher than RMS of amp) that would stop the amp from shorting itself from a blown driver or grounded speaker lead.
                    josh
                    01 Bullitt... missing some interior parts
                    88 conquest tsi- finally got a v8 for it..
                    some pics
                    http://picasaweb.google.com/bullitt01536
                    • T BONE
                      UNCLE BEARD
                      • 11494
                      I have a PPI a1200 art series. It doesn't work and smells like piss.
                      • T BONE
                        UNCLE BEARD
                        • 11494
                          GUYSIS
                          • TitaniumGT
                            • 11042
                            GUYIS
                            All of them!
                            446RWHP and 585RWT
                            Vortech S-trim
                            346rwhp and 314rwtrq
                              Originally posted by TitaniumGT View Post
                              All of them!
                              THE SKIES OF DUMP ARE SEEN!
