dose someone know if the bolt pattern on the crank of a 351w changed between years? because i found a 351w out of a 69 galaxy for cheap. want to know if its the same as 80's crank. i know that the 302w's changed so just want to make sure thats all.
351w crank bolt pattern
The bolt pattern has not changed. Balance weight changed. The old 351s are 28oz your roller 302s are 50oz.Don't ask, it's a midlife crises thing.
www.transport-graphics.com
www.knowltonsthunderheads.com
www.dukesraceshop.com
www.meanstreetperformance.com
www.fleetwoodcollision.com
www.idealautoglass.net
That is the balancer on the front not the crank. If you use the right weight, you can interchange all the balancers. You will have to space out your pulley to line up.Originally posted by Max Power View PostThe 351 cranks changed from a 3 bolt to a 4 bolt mid-year 1969.Don't ask, it's a midlife crises thing.
28oz, yes, use a 157 tooth and it will bolt on for a T-5Originally posted by merkurmike View Postso dose some one know what the imbalance of a 69 351w is?(28once or 50 once)Don't ask, it's a midlife crises thing.
It will bolt up fine. Be careful the T5 is not built for the Tq of even a mild 351.Originally posted by merkurmike View Postgood because thats what i have. just wanted to make sure. thanksDon't ask, it's a midlife crises thing.
