Sooo....how much more timing can I run with 110 octane?
  • KrisR
    KNT-SHO
    • 12737
    Casey tuned my car pretty conservatively, with only 19 degrees of total timing (and only 8psi peak boost). I usually run 92 octane only. I was going to try some 110 leaded at the track, and was wondering how much I can rotate the ole' distributor.
    I was thinking 4-5 degrees?
  • RACER
    Street Racer
    • 806
    I would say if your going to drain "all" of the 92 out you "might" be able to get away with it. If mixing....2 maybe 3 degrees.
    You usually dont get any chances before you lift a headgasket
    Why risk it though if you are selling it? Head gaskets are no fun
    • Max Power
      • 13086
      57 degrees.
      • I Tried
        Pull my Winch Line 4 Me.
        • 6103
        You will know when to stop. It will poop out a headgasket.
        • mustang cobra93
          PROCHARGER
          • Mar 2007
          • 3964
          110 leaded?? Your o2 sensors won't like that.
          105 unleaded.....28-30 total, if that's all in the gas tank no mixing it with 92, just straight 105 and if you can't find 105 go with 100 unleaded and you should be able to run 25-28 total.
          "The power of the RIFF compells me"
          "Champipple"
          • Mullet Tuner
            • 15906
            I would be conservative, Kris.
            Originally posted by Gerald
            • Novi2KGT
              • 1758
              How high are your IAT's? And what heads do you have again?
              • KrisR
                KNT-SHO
                • 12737
                1. I don't know. I know Casey has it set up to pull 3 degrees out if the IATs go over a certain temp. He might remember where I'm at.
                2. J302 aluminum Ford heads.
                • Novi2KGT
                  • 1758
                  I would think you'd be able to get away with 25-26ish easily on that little of boost, but I'm no tuner (only on my own car) I'd talk to Casey and see what he suggests.
                  • wiplash
                    2014 TT/GT
                    • 3479
                    I'd second that. With my V2SQ I ran 12-13lb's and about 20 deg's total on pump gas, at the track I'd add 6-8 degrees with the "mystery" Mobil 111, probably could have added more since I was intercooled.
                    -No one ever
                    • KrisR
                      KNT-SHO
                      • 12737
                      Thanks for the info everyone. I may try it, I may not.
                      • Bmikkalson
                        • 3333
                        To many variables, you can add timming and lose power also. MBT is a fine fine line on boost.
                        MR,POWERS
                        "Well now you know. Cops break laws all the time, luckily for them they aren't held accountable for most of their infractions."
                        New Generation Auto, CJ performance Package STAGE 2
                          Where can you buy 100 unleaded now? Most places stopped carying it in favor of E85 I thought.
                          • HerrKooled
                            • 12060
                            plymouth has it.
                            damn near 7 bucks a gallon though i do believe.
                              Originally posted by HerrKooled View Post
                              plymouth has it.
                              fuck that, I wont pay that, even for that sweet, sweet smell
