Speedometer gear
  • Dave90GT
    Looking for a 911 SC
    • 3051
    Speedometer gear
    What speedometer gear do I need with a T-5, 8.8 inch rear and 3.73 gears? I think it's the 21 tooth red one. Is this correct? Thanks!
    Dave
    I know it is red. But I can't remember how many teeth. I called Summit Racing and they were able to tell me the Ford number If I remember right, then I called the local Ford dealer and had them get me one. Nick
    • Dave90GT
      • 3051
      Thanks Bro!
      Dave
        Any time. Nick
          for some reason i am thinking that it might be a 23 tooth gear. :idiot: dave, just call up a performance shop like db and ask, they will be more then happy to shed some light on your question.
          • -D
            eat shit..eat my shit
            • 2708
            99.99% sure its a 23 tooth, let me know where you got yours, and how much, I need one too
            • lilstang5O
              • 9204
              red gear
              I had my speedo off when had gotten gears. I have a extra 22tooth red gear that ya can have fo FREE. I put in a purple 21tooth and I only have 3:27's in the rear 8.8 rear end. Im guessing that ya will need a 22 tooth from what i undstand. Its only $7 from Apple Valley ford! I'll have too look in the garage tomarrow and see If ts still whereI left it.
              Ride:
              • 5.0Cobra
                • 224
                You need the white 23 tooth speedo driven gear, assuming you still have the stock '93 transmission with the 8 tooth drive gear. Your speedometer will still read a little bit high, but with that's a close as you can get (no 24 tooth gears). Also, the 23 tooth wear out very quick.
                If you want to have it right on, you have to change to a 7 tooth drive gear like '83-'89 T5s and use a 21 tooth red gear.
                • Dave90GT
                  • 3051
                  I think I'll have to get a 7 tooth drive gear. Thanks.
                  Dave
                  • 5.0Cobra
                    • 224
                    The only catch with the drive gear is it's harder to replace. You have to remove the tailshaft housing from the tranny to access it. Supposedly it can be done without removing the tranny from the vehicle.
                    • Dave90GT
                      • 3051
                      Fuck that. Maybe I'll just leave it the way it is, with the speedometer needle bouncing and the speedometer incorrect. Is this something a dealer could fix? Or wouldn't they want to fuck with it since it's not factory?
                      Dave
                      • redv6Lance
                        tcs has-been
                        • 434
                        dude i got a number you can call and theyll send you teh right speedo gear for 17 dollars total after S&H i got mine. SIMPLE install
                        • Dave90GT
                          • 3051
                          A 23 tooth gear that will wear out? No thanks. I'm doing it right or not at all. I'm about a month away from driving this fucking Cobra off a cliff.
                          Dave
                          • redv6Lance
                            tcs has-been
                            • 434
                            uhh well its not gonna wear out any faster than one youd get straight from Ford Performance. PLastic is PLastic, shit....
                            • -D
                              • 2708
                              Manual Transmission with 7 tooth drive gear
                              83-89 V-8, 96-98 Cobra 5-speed, Tremec TR-3550 & TKO
                              2.73 16 tooth maroon
                              3.08 18 tooth yellow
                              3.27 19 tooth pink
                              3.55 20 tooth black
                              3.73 21 tooth red
                              4.10 23 tooth white
                              manual transmission with 8 tooth drive gear
                              90-98 5-Speed except 96-98 cobra
                              2.73 18 tooth yellow
                              3.08 20 tooth black
                              3.27 21 tooth red
                              3.55 23 tooth white
                              3.73 23 tooth white
                              It all depends on what tooth your internal drive gear is.
                              I would assume a 93 Cobra would fall under the 8 tooth drive gear, my resources say nothing about a cobra under a 96 model year
                              Hope it helps all who are wondering
