What else would I need too run a supercharger?
  • 91GTstroked
    • Jan 2006
    • 1893
    Currently the cars pretty much stock, only mods are as follow; 70mm tb, 75mm mass air, bbk cold air kit (which would be gone of course) pullies, aftermarket shorty headers, stock h-pipe, force II catback, short throw shifter. I think the gears are stock as well. I'm looking for a mild s/c kit prolly the newer paxton SL which throws about 5-6psi. I want some more hp but dont want to throw HCI on it yet, just a s/c. Should I go with 42lb, 255lph fuel pump, and a tune? Plan on doing this within a year just need some ideas right now, thanks!
  • lilstang5O
    any pony power left out there?
    • 9204
    Talk to Blackstang50, he did that and had pretty much the same setup too!
    Ride:
    '97 Mustang GT a.k.a. BLACK SUNSHINE!!
    • Frankenstein
      SWAMP *****
      • Jun 2004
      • 3298
      I want your car
      Expect nothing less, maybe more. :idiot:
      Originally posted by HerrKooled
      OH SHIT AND IT'S OLD MAN OUT OF NOWHERE!! BOW!
      • 91GTstroked
        • Jan 2006
        • 1893
        Originally posted by Frankenstein View Post
        I want your car
        thanks, I'll let you know if I ever sell it
        • Frankenstein
          SWAMP *****
          • Jun 2004
          • 3298
          • Nasssty
            • 424
            When I was running my a-trim on my car all I did for a fuel system was 42lb injectors, 190 LPH fuel pump and a custom tune. You don't need to go with larger injectors but it allows you to ditch the FMU.
            • Sweet35th
              Tuning Deity
              • 4768
              The paxton unit, is a great entry blower (the SL or the Novi1000). Both can make 500rwhp without issue. 42# injectors, the 255lph pump and an upgraded MAF, and a good tune are all you will need to make it work. The 5-6psi kits usualy do not come with a bypass, so I recomend upgrading to the higher output kit, so that you get the bypass as well. 8-10psi on a stock motor is just fine.
              I send myself PM's so I roll with a full inbox! Sweet35th style!
              • 91GTstroked
                • Jan 2006
                • 1893
                thanks for input, if I went with a 8-10psi kit which brand should I go with? I like the paxton SL because its self lubricated no tapping into the oil pan. I havent seen paxton advertise a 8-10psi kit for the SL system yet. Another question, I have a 75mm pro-m mass air, thats set up for 19's do I need to get it recalibrated or can you guys adjust it on the tune or ditch it and get a different one? Starting to save my pennies, but you will see me in the future for a tune
                • Eric S
                  • Feb 2006
                  • 550
                  you could probably get away with 36 lbs injectors they are cheaper but if you ever went with a bigger s/c you have to upgrade to 42's
                  • 91GTstroked
                    • Jan 2006
                    • 1893
                    Anything wrong with these summit 42's?
                    • Sweet35th
                      Tuning Deity
                      • 4768
                      • Sweet35th
                        Tuning Deity
                        • 4768
                        Your right, it doesnt look like they have the Novi 1K kit anymore......I recomend you call them directly and talk to them. Let them know your looking for a kit with a bypass, and in the range of the Novi1000. They may still have some kits on the shelf to sell.
                        I dont know the range of yoru Pro-M meter. I can certainly tune with it, but I dont know if it will peg or not. If it pegs, thats the problem, and we need to upgrade to a larger meter..
                        • 91GTstroked
                          • Jan 2006
                          • 1893
                          sounds very good, thanks for your help again. I will contact you in the future!
