89 F150 + Low Range Light
    Had something goofy happen today...
    Low range light on the 89 Came on and wont shut off.
    Truck will go in and out of 4 wheel high/low fine. The low range light never turns off.
    89 f150
    5.0
    5spd
    Manual Transfer Case
    Manual locking hubs.
    Fuck
      probably just a sensor sticking mine does that sometimes
        Tell your buddy to call me if he wants that tranny.
        • lark-o
          • 10489
          its old and its cold shits happens
            ill see
            • Steve
              eMechanic
              • 5381
              How many threads are you gonna start for this truck this week?
                The truck is mint though.
                • Dustball
                  My title here
                  • 3251
                  Either have a stuck 4-lo switch at the t-case or a short in the 4-lo switch wiring.
                  • ejholmgren
                    • Oct 2004
                    • 1852
                    At least the clutch slave didn't piss fluid all over the clutch/flywheel at the 169/81 intersection
                    smoke gray cat mafia (Barn cat)
                    R.I.P. 1/4 mile cat. You died doing what you loved best ... running in front of cars going 120mph.
                      Nope...
                      I found the cause. this can be locked up.
                      • Pauly
                        It's Gone!
                        • Jun 2007
                        • 2870
                        well what was it. Please enlighten us!
                        • bigblockpaul
                          i live my life a quarter mile
                          • 4137
                          At least yours goes into four wheel...Mine just clicks under the dash and nothing happens????any thoughts
                              Well i found 2 things...
                              1) The shift Rod from the floor shifter to the Transfer case is loose... Don't even know HOW it went into 4 wheel when i used it the other night.
                              2) Apparently the CableThing that held the wiring around the tranny/sensors and whatever else under there Rusted/broke/or walked away from the truck as it is no longer there... The wires were loose, and apparently the uber high speed 20 mph corner swayed the wiring into the knuckle for the front drive shaft and cut it. So, i get to get under it, strip, splice, tape and re align all those wires. Then make sure it wont happen again .
                              Not a huge deal, something ive never had happen before..
                              I've owned 3x 4x4 bronco's and this is my 5th 4x4 F150. First time ive ever had either of the above 2 happen. Same with the tank issue, on all the trucks ive owned with dual tanks, none of them ever had an issue.
                              Little things. I'm glad they are happening now, and not later. Like when im out in Northern MN with nothing around!
