90mm Mass Air - foxbody
  • turbodan
    Belt Driven
    • 191
    how do i put a 90mm lightning mass air meter on my 1990 5.0?
    i know i need the mass air off a lightning for 42# injs.
    a 6 pin-4 pin harness
    and a 4 bolt flange for the clamp on air filter
    but...
    where is the best place to buy these things?
    does anyone sell it in a kit?
    do i have to have my car tuned or can i just bolt it on?
    thanks, Dan
    "Happiness is being STROKED and BLOWN at the same time"
    You might be able to get everything from brothers performance, but I'm not sure.
    If you are going to 42's, why wouldn't you get it tuned?
    • turbodan
      Belt Driven
      • 191
      i have 42# injs. and a 76mm C&L now and the car runs fine with stock tune!
      I was planning on getting it tunned if i switch to the 90mm, but was wondering if it would work for a while un-tuned?
      I don't know if i should be messing with stuff the car works good now?
      thanks
      • Nasssty
        • 424
        Pro-m sells the 4 pin to 6 pin adapter
        • EFI Performance
          EFI is back!
          • Dec 2005
          • 636
          The car would need to be tuned.
          The transfer table between a 42lb maf and the stock lighting maf are different. The car would actually go lean on the higher rpms.
          It's a easy change to make in the tune to correct for which maf sensor you would be running.
          Russ
          • xcsboost
            Got Oil Bitches
            • 2810
            diversified sells them with 42's for like $280 bucks already pinned as well
            • turbodan
              Belt Driven
              • 191
              thanks for the info.
                Do they have a website?
                • Nasssty
                  • 424
                  Here is the link to Diversified and the 42lb'rs with Lightning MAF
                  Find information, resources and relevant links for buyfordracing.com. This domain may be for sale.
