Dual Gas Tank Question
    Hah, full of em this week.
    I've never had this issue on a Dual tank before..
    When the Front Tank and rear tank is full...
    And i have the front tank selected, why does it start overflowing out of the gas cap? I know there was a recall for the valve in the line or whatever on these ford trucks, but ive never had one do this.
    IM guessing this is the issue, but, i do no know...
    Cliffs:
    89 F150 W/Dual tanks.
    When both tanks are full and the Front tank is selected for fuel source, it overflows. However with both tanks full and rear tank selected, it does not overflow.
    the recall was done on my truck without it the fuel transfers between the tanks dont know the logistics of it all but i seemed to do the trick
    • Dustball
      My title here
      • 3251
      Go to Ford and give them the VIN, see if the recall has been performed on your truck. If not, they'll do it for free.
      NHTSA CAMPAIGN ID Number : 91V146000
      Make / Models : Model/Build Years:
      FORD / E150 1989-1991
      FORD / E250 1989-1991
      FORD / E350 1989-1991
      FORD / ECONOLINE 1989-1991
      FORD / F150 1989
      FORD / F250 1989
      FORD / F350 1989
      Manufacturer : FORD MOTOR COMPANY Mfr's Report Date : SEP 04, 1991
      NHTSA CAMPAIGN ID Number : 91V146000 EA91031
      NHTSA Action Number: EA91031
      Component: FUEL SYSTEM, GASOLINE:STORAGE:AUXILLARY TANK:SELECTOR DEVICES
      Potential Number Of Units Affected : 350000
      Summary:
      THE DUAL FUEL TANK SELECTOR VALVE MAY MALFUNCTION AND CAUSE AN OVERFILL CONDITION IN ONE OF THE FUEL TANKS, RESULTING IN AN OVERFLOW OF FUEL PAST THE FILLER CAP.
      Consequence:
      THE OVERFLOW OF FUEL PAST THE FILLER CAP CAUSES A FUELLEAKAGE, WHICH CAN RESULT IN A FIRE WHEN EXPOSED TO A SOURCE OF IGNITION.
      Remedy:
      REPLACE THE DUAL FUEL TANK SELECTOR VALVE.
      Notes:
      SYSTEM: FUEL TANK, AUXILLIARY.VEHICLE DESCRIPTION: VANS AND LIGHT TRUCKS WITH DUAL FUEL TANKS PRODUCED IN THEFOLLOWING PERIODS: F150, F250, AND F350 LIGHT TRUCKS BUILT BETWEEN FEBRUARY 28,1989 AND JULY, 1989; ECONOLINE BUILT BETWEEN FEBRUARY 28, 1989 ANDFEBRUARY 11, 1991.NOTE: FORD HAS AGREED TO RECALL THESE VEHICLES BUT PARTS ARE NOT YET AVAILABLE.PARTS WILL BE AVAILABLE IN DECEMBER 1991. YOU WILL RECEIVE A LETTER FROM FORDADVISING YOU WHEN TO SCHEDULE AN APPOINTMENT WITH YOUR DEALER TO HAVE THE RECALLWORK PERFORMED. IN THE MEAN TIME, YOU CAN TAKE THE FOLLOWING PRECAUTIONS:FILL EACH TANK TO ONLY 1/3 FULL.IF YOUR VEHICLE LEAKS FUEL OR IF YOU SMELL FUEL, STOP USING THE VEHICLE ANDCALL FORD AT (313) 446-4654 AND ADVISE THEM OF YOUR PROBLEM. REFER TO FORDSAFETY RECALL NUMBER 91S39. AN OPERATOR WILL TAKE YOUR NAME AND TELEPHONENUMBER. A FORD REPRESENTATIVE WILL CALL YOU BACK.
        Hmmm
        I called and they didin't show an OPEN recall on the truck. Although it does fall into this recall.
        Ford doesnt keep info past 10 years any how. I don't know that this is still open...
        They quoted me $300 to replace the valve. I said no thanks.
          • tirenick
            Pimp of Tires
            • 6255
            Yeah get it fixed....it stunk up my shop
              use one tank
                Yah didint know about the whole overflowing tank until i got there.
                It shouldnt have... unless some one switched it back to the front tank...
                • tirenick
                  Pimp of Tires
                  • 6255
                  I don't know...coming to get it????
                    Replace the valve yourself.
                    • Dustball
                      My title here
                      • 3251
                      $62-$74 at Rock Auto.
                      • Pauly
                        It's Gone!
                        • Jun 2007
                        • 2870
                        That exactly what it is a check ball gets stuck open the transfer vavle and fills the front tank what I used to do was run the front tank down then switch it to the rear so it would fill the front again and switch back to the front. And come to think of it there was a noticible power difference in the engine when I would switch tanks. Bottom line is it does need to be replaced. Also I think it might all be one assembly coming out of the tank.
                          I would drain the front tank down, but if i attempt to drive on it, it overflows
                          • Pauly
                            It's Gone!
                            • Jun 2007
                            • 2870
                            You gotta do something drive till you see fire then get out and run like hell if no fire keep going or go faster to put out the flames.
                              Ima go do that right now.
