to buy or not to buy?
  • tittan1500
    Got Automation!!!
    • Nov 2007
    • 77
    ok guys i have a deal pending on a set of 291 camel back heads they are the small chamber and they have 1.95 intake and they have been stored inside and are cleaned up. the guy wants 200$ should i buy them or let these heads go the way of the dinosaur.
    they would make a good addition to my 305 or the 350 with some home porting and port matching
    so buy them or not i am torn help me out
    2000 LS1 TransAm NHRA
    3200 stall long tubes borla cat back
    Midnight blue and silver 86 Z28
    tan interior
    305 Comp Cams XE268H , Edlebrock 600cfm carb, weiand action plus intake
    Mallory ignition system
    headers with Magnaflow muffler.
    98 Z28 10 bolt
    :3gears:
    those are a nice head, i would buy them
      you will make way more power with a set of vortecs, vortecs new are 500 loaded. you will have more then that in to those heads after a valve job
      • 289Notch
        Lowballer
        • 7340
        I would personally spend a few hundred more and get a set of used aluminum heads already cut for 2.02s. Not that it really matters cause anything used is gonna need a valve job.
        I had a set of camels that had tons of porting. Was just a sliver of metal between the ports.
        on a 355 they pushed my nova to 10.9X.
        Mustangless!
        • Pauly
          It's Gone!
          • Jun 2007
          • 2870
          200 bucks buy you'll be able to sell em for the same even if you don't use them. They are a good set of mild heads. good match for the anemic 305. I say buy not often you get an ok head head right out of the box. For cheap
            vortec = more better
            • 289Notch
              Lowballer
              • 7340
              what really matters is the valve job. So these are clean. Big whoop. That's like 40 bucks. a valve job is 200 plus. camel back heads were hot in the 80s at best. now there are thousands of sets of nice AL heads around. and yes vorteks pwn.
              Your budget needs to be 100 percent defined to be able to answer your questino.
              dalkfjadl adfjla
              .ads.faakj...ekjr
              Mustangless!
              • off white
                • 314
                plan on buying acc. mounts camelback dont have any for alt.
                • tittan1500
                  Got Automation!!!
                  • Nov 2007
                  • 77
                  ya the heads are old tec big time i think i will look for a set of vortecs so when i switch engines i will have a head that can make some power unitl i can aford some dart pro 1 heads.
                  if i found a set of vortecs how much lift can thay handle stock?
                  what is the average price for a set of vortecs?
                  tan interior
                  98 Z28 10 bolt
                  :3gears:
                  • Outlaw86'd
                    bite it you scum
                    • 3301
                    nothing except a chain attached to the bow of a boat is a good addition to a 305. those motors are WORTHLESS. unless you plan on putting these on a real SBC save your coins.
                    • RegalX
                      Model A Mafia
                      • 3154
                      I have a set of 487 heads I'll sell you. 76cc chambers. around 5k since valve job.
                      • RegalX
                        Model A Mafia
                        • 3154
                        Why are they "worthless"? They used them for years and put them in everything. Same oiling system, cooling, everything as a 350 it just has a 3.736'' bore compared to a 4.000'' on a 350.
                        They may not be must for making power, but they are far from worthless.
                        • Outlaw86'd
                          bite it you scum
                          • 3301
                          thats what i mean. there are much worse motors out there..the 307 comes to mind i mean in terms of spending money and time to put heads on them..why bother? you're not going to make any power with it if he wants to make more power he should just drop a few hundred for a decent 350 and a cam. he'd already be making more than a 305 with all the bolt ons in the world
                            I think they're worthless too. They don't get any better fuel economy and lack power. It was only in the last few years of the Thirdgen that they made any kind of gains at all (205 hp), and even then the V6 put out more power in the '90's.
                            They gave the Thirdgens a bad rep.
                            • RegalX
                              Model A Mafia
                              • 3154
                              third gens gave third gens a bad rep
