Oil Pumps
  • GarrettGTX
    • 3648
    Oil Pumps
    what oil pump do you run in your 302 based engine? Which have you had good or bad luck with?
    cunnilingus with a side of coitus
  • 289Notch
    Lowballer
    • 7340
    melling stock replacement or high volume. doesn't matter. the high volume just makes max pressure faster.
    Mustangless!
    • mg72
      All Hondas All the Time
      • 1955
      Melling stock volume. The only two reasons for hv or hp pumps would be a race only or forced induction setup which requires an oil feed. Otherwise it's lost horsepower.
      The Jimmy hat is off.
      • xjfish
        siiiiiiick!
        • 7357
        Did some research before I replaced the one in my old 5.0 F150: Melling stock volume. Priority main oiling for non race setups!
        1987 Oldsmobile Cutlass Ciera
          We are going with I believe a precision pump in my 347.
          PM ds5dot. He will let you know which pump we are going with....
            Had A stock pump in mine, with a oil line feed blower, no issues, had 65PSI cold and around 50PSI warm.
            • Racin Repair
              You wish!
              • Mar 2005
              • 2166
              Titan
              9.10@142 on DOTs thru the mufflers, back when I used to race...
              • ds5dot
                RS/N Champ 2009
                • 1657
                Originally posted by Racin Repair View Post
                Titan
                Only if you can fab the pick up!! The pick does not fit a 302 and they do not make one. You have to make a 351 pick fit.
                Thanks to:
                www.meanstreetperformance.com
                http://transport-graphics.com/
                http://knowltonsthunderheads.com/
                http://www.normstire.com/
                • Racin Repair
                  You wish!
                  • Mar 2005
                  • 2166
                  Didnt know that.. Makes sense thou that dont even make em for those itsy bitsy 8.2 pos's...
                    melling high volume.
