really shitty brakes....
    hey i just replaced all the brakes(front pads/rotors-rear pads/ rotors) on my my 2002 yukon denali xl. ive driven it for about 400 miles and they have no bite i bought the best of everything from kath. the thing doesn't stop for shit and i dont see anything obvious,i dont hear any vaccuum leaks or anything-----any ideas?
    Improper break in? Did you wash the rotors before installing them?
    • Pauly
      It's Gone!
      • Jun 2007
      • 2870
      There usually a film on the rotor wipe down with alcohol or some kind of non greasy cleaner. Try and bleed brakes. I agree also with the possibility of improper break in
        no need to bleed them unless you cracked the system open. Did you clean the grease off the rotors? Did you seat the pads. Shouldnt be a huge deal if they werent broke in correctly but it might be.
        • Steve
          eMechanic
          • 5381
          What do the rotors look like? Street pads are abrasion type brake pads. If the rotors are very smooth, you need to scuff them. This is why tech's will scuff rotors after turning them. Pads need a rough surface to get a good transfer of pad material onto the rotor.
          • taank
            • 10278
            have the rotors turned and scuffed, when apart take some sandpaper and lightly sand the pads before reinstalling
            Jake H.
              yea i cleaned them very well with brake cleaner and scuffed the rotors -didnt really use the brakes hard either--damn thing just doesnt seem to stop like it should, i know its a heavy truck but it doesnt seem right-anyone recommend a good shop who may be able to diagnose the prob?
              • Racin Repair
                You wish!
                • Mar 2005
                • 2166
                You should have gone and hit the brakes hard from about 70 and then let them cool and repeated this about 3 times. You need to get a few good heat cycles in them for proper bite.
                9.10@142 on DOTs thru the mufflers, back when I used to race...
                • tirenick
                  Pimp of Tires
                  • 6255
                  NORM'S TIRE!!! pm me
                  • Vibrant93
                    9SECLX.
                    • 1212
                    www.denalitrucks.com check it out, lots of good info over there.
                    The 02-04 sierra denali and yukon denalis have a master cylinders that are too small. My truck is the same way.
                    The Cobra
                    http://i111.photobucket.com/albums/n...awithneal1.jpg
                    The Coupe
                    https://www.youtube.com/watch?v=Gxl54aGMNxg
                      pull the pads and rotors off, get the rotors turned and scuff the pads. Then seat them like racin repair says.
                        Take it from this guy he knows how to power brake yo!
                        So we need to see the million foot burnout from souther's again. That was just plain ssssssssssssssick.
                        • Turbo302
                          • 1528
                          Does it seem like you have plenty of pressure (hard/firm pedal), but no bite??
                          Or does the pedal seem soft??
                          Do you know if you went with Semi-Metallic or Ceramic pads??
                          Before taking anything apart, do 2-3 heavy stops from 70 or so down to 15-20mph and let them cool after. Then try them and see if they are any different.
                          What I have noticed in many of the new Ceramic Pads, is they dont bite quite as well as a good ol semi-metalic in heavy vehicles. I installed some Ceramic Raybestos "QS" series pads on my 2500 4x4 Ram and it requires quite a bit more pedal pressure than it did with semi-metallic pads.
                          They dont throw the dust, but do require more pedal pressure.
                          My $.02
                          Tim
                          1988 5.0 Notchback
                          • mg72
                            All Hondas All the Time
                            • 1955
                            I think turbo 302 has it. Pad material is the key to a better bite, especially if the truck is known for an undersized master cyl. Get the hd pads rated for towing-probably a semi metallic. They dust more, but it sucks worse to not have good brakes.
                            The Jimmy hat is off.
                            • Racin Repair
                              You wish!
                              • Mar 2005
                              • 2166
