Ok Well lately for about a week or so my car has started to run like crap. It idles really low at like 600rpm and when i get in the car after letting it sit for a hour or so when i put it in reverse the car starts but when it starts it doesn't do the normal high rev up then slowly go back down to normal. But it rather starts and doesn't do that but like the engine isn't getting any fuel, like starting the car and it instantly goes to idle.
Then when i put it in gear it bogs down almost like its getting starved and dies if i don't keep the gas up for the initial startup. ALso when im on my hill at work (car pointing down at a incline) it stalls there also but at normal lights it idles but really really low.
Now to the pressure regulator question, macs stang and i noticed when i turned the car off the fuel presure went right to 0 after being at operating temp. Normally it would stay at like 15psi or so after the car was off after being runned for awhile. Plus when i start it i have to turn the key twice to basically prime the car to start. Otherwise the car turns over a shitload to start.
Highway cruising seems normal. I think my bbk fuel regulator is taking a shit so any more input would be helpful.
Also i think my idle might be set too low so im going to bump that up tomorrow to see if it helps.
