Anybody know what could be wrong?
  • Black87GT
    Keyboard Warrior
    • 996
    ok, well i just finished my stock to cobra intake manifold swap, and have run into alot of new problems, i also replaced my brake pads.
    Well, when i pump the brakes now, its like all air, you can hear it, and the brakes barely work..
    Also, the motor seems to be running VERY hot, after like 20 min. its extremely hot, if you open the hood the heat just comes out at you..
    And after installing the new intake, my exhaust has ALOT of back pressure, and when i let off the gas at high rpms, it starts to cackle and stuff really bad, like an exhaust leak, that was not there before the intake swap... this stuff is pretty hard to explain, sorry, ANY help would be appreciated...
    Thanks TCS!
    '87 Gt- (Black) Underdrive Pulleys, bbk long tubes, Weld Draglites (Big and Littles), 3:73 Gears, bbk o/r H-pipe, 2.5" Flowmaster 40s, Cobra Upper/Lower intake, pro 5.0 short throw, zoom stage 3 clutch and flywheel, No smog equip., Soon to have an Aluminum D/s
    '97 Explorer Sport - (Green) All Stock 4.0, Runs great (DD)
    http://www.cardomain.com/ride/2574854
  • SmithEvo
    Poppin' VTAK yo!
    • Nov 2004
    • 25468
    Thanks TCS!
    Bleed the brakes. Did you fuck up the thermostat when changing intakes? I dunno about the exhaust shit.
    Not at the table, Carlos.
    • Pauly
      It's Gone!
      • Jun 2007
      • 2870
      did you top of the block with coolant before you put the thermo back in. some times you run em dry and the therm doesn't open like it should. are you sure you didn't block any coolant passages for the intake. It does happen. as far as brakes bleed the shit out of them. and make sure they are moving
      • Chrm97PI
        268ponies with more onthe way
        • 3413
        did you install new rotors or get them turned, sometimes just pad slaping rotors will cause lack of braking, or like other said bleed the fuck out of them
          if you didnt crack the system you shouldnt need to bleed the brakes. If you opened the system then bleed them.
          Are your coolant passages all free and clear?
          • NAZISALEEN
            Afro Samurai
            • 12235
            Odd, something doesn't sound right.
            You didn't run the egr coolant line to the cobra intake did you??
            If you did do not run it anymore, it is injecting antifreeze directly into the intake.
            • SmithEvo
              Poppin' VTAK yo!
              • Nov 2004
              • 25468
              Big whoop wanna fight about it
              • NAZISALEEN
                Afro Samurai
                • 12235
                Yeah so what I have an underground tunnel, big whoop wanna fight about it????
                • SmithEvo
                  Poppin' VTAK yo!
                  • Nov 2004
                  • 25468
                  I'm off to go fight a chicken
                  • NAZISALEEN
                    Afro Samurai
                    • 12235
                    • SmithEvo
                      Poppin' VTAK yo!
                      • Nov 2004
                      • 25468
                      • NAZISALEEN
                        Afro Samurai
                        • 12235
                        NOICE!!
                        Hot Meg!!
                          sounds like you have a major vacuum leak. that would lead to poor braking and the cackling in the exhaust.
                          about the overheating, sounds like you did something wrong. did you install the thermostat backwards?
