Alternator wiring?
  • Steve
    eMechanic
    • 5381
    Alternator wiring?
    Alright, I am starting to design the wire harness for my car after I tore out every bit of wire/hose in the car. I do have questions about the 2G alternator harness.
    All wires except the green with red chaser end up together in a ring terminal that goes on the positive side of the Starer Relay. I see the Green w/ red chaser is for the gauge, but does it also energize the field or is that done via battery power from the relay post?
    Do I need to wire the volts gage to the igntion switch?
  • onewickedstang
    umm sure
    • Mar 2007
    • 206
    100% satisfaction guaranteed on every domain we sell. 30-day, no questions asked, money-back guarantee. Easy, fast and convenient shopping.
    not sure if this will help any or not.
    86 notch: 393W/c4 combo.......best of 10.63 @ 124.98 so far.
    89 notch: the new project
    99 contour: puddle jumper
    • Steve
      eMechanic
      • 5381
      This one looks a bit better...
      • Steve
        eMechanic
        • 5381
        Why does the gage wire need to be hot in run?
        Just to activate the gage?
        • svonasek
          • 1641
          You wire an amp meter the way I told you. A volt meter could be hooked to any hot wire and any ground.
          • mg72
            All Hondas All the Time
            • 1955
            I found out the hard way that the charge indicator is required for the alternator to operate.
            The Jimmy hat is off.
            • Steve
              eMechanic
              • 5381
              Did you run the green wire to a volts gage and then to the ignition switch?
              • mg72
                • 1955
                I had the cluster out with a no-charge situation. Reconnecting the cluster solved the problem. I believe its looking for a specific resistance. Those diagrams should have the answer.
                • svonasek
                  • 1641
                  Weren't you switching the car over to a new style alternator?
                  They show the cluster as being optional. It looks like you should just run the green wire to ignition power. The 2g alternator uses that one as the field wire.
                  • Steve
                    eMechanic
                    • 5381
                    I plan to to use the 2 G for now and this chart shows the cluster being optional.
                    Must not have worked on MG72s car because he broke the field circuit.
                    • Steve
                      eMechanic
                      • 5381
                      Never mind got it working. Runs great, 14.25 volts and the switch kills the car.
