Driving with slicks?
  • RedStal95
    Genius
    • 1336
    I have 26x8.5 MT Drags mounted on 15" v6 rims (tubeless). When I'm racing down the track I cant keep my car straight. It pulls left, right, left, etc. It's a little bit scary. People have told me its because I have radials in the front and the problem will go away if I get skinnies. Is this true?
    Also, when I'm at the track I have the slicks at about 14psi. If I jump the pressure to about 22 do you think the car will be driveable on the street?
    I'm just sick of these awd cars owning me on the street. My goal is to pull 1.7's on the street and take their little 4cyl awd asses to school
    Thanks
    Andy
    Stock 95 GT **SOLD**
    http://www.maperformance.com
    -B-S-M-
  • bigblockpaul
    i live my life a quarter mile
    • 4137
    I run 28by10.5 15 inch et drags on my car with radial skinnys on front....You will get a little sway down the track thats the norm on slicks..I run mine at 10 pounds???Paul
    • RedStal95
      Genius
      • 1336
      I need to buy skinnys. Paul do you ever drive your car on the street with the slicks on?
      Andy
      -B-S-M-
      • KrisR
        KNT-SHO
        • 12737
        It's normal, especially with the little 8.5" wide ones.
        I would recommend not driving on them on the street, because of legality issues, rain potential, etc.
        If you want something for the street, I would sell them and get some ET Streets or Drag Radials or other DOT stickies.
        I run McCreary (Now 'American Racer') G60-15 (equivalent to a 245/60-15) wrinklewall dirt-compound DOT tires on my GN and they hook very nice, even at 32-psi street pressure. Plus, they are only $190/pair shipped, and they seem to last quite awhile. At the track, heated up at 14psi pressure, they should be great!
        Just an idea...
        Kris
        • drag79stang
          grumpy old fuck
          • 592
          I"ve run as little as 5 pounds in my 31"s, (at the track ONLY), and THEN it handled kinda funky at the big end. But normally run 9 pounds, (little less at slippery rock), and have no handling issues to speak of.
          My .002
          You can sleep in your race car, but you can't race your house!
          • bigblockpaul
            • 4137
            no
            I run a bfg street ta with no traction at all...I am looking into the new drag radial by mt...
            • theduckylittle
              Duck uber Alles
              • 5435
              Well, this is just one of those "maybe overlooking the obvious questions" ... what's the condition of your Trak-Lok unit? If both wheels are enguaged properly then you should see some sway but nothing violent (like on my 7.5" one-wheeler that will get squirly fast).
              -Duck
              • RedStal95
                Genius
                • 1336
                -Duck
                Hmm good point. I've been thinking my trac loc may need a rebuild.
                I posted this on the corral..
                "If i drop the clutch I do a big burn out with both tires spinning. If I turn the wheel to the left and give it gas I do donuts. If I turn the wheel to the right and give it gas, I go nowhere and only my right tire spins. Every once in a while when I'm at the starting line warming up my slicks, only my right tire will spin, even though most of the time both spin.
                Is it time for a trac loc rebuild?
                What do you guys think? If yes, could it be causing my violent swaying at the track?
                Thanks
                Andy
                -B-S-M-
                • theduckylittle
                  Duck uber Alles
                  • 5435
                  Yeah, sounds like your trak-lok unit may not be up to snuff right now. That happens with the clutch-type torque-biasing units... they wear out ... especially when a large amount of torque is applied to them. (Aka a warmed over V8 with sticky tyres would cause some "out of specification" stress.)
                  -Duck
                    do you have any loose suspension components? worn bushings etc that might have excessive play under full acceleration?
                    possible doglegging?
                    are you jerking the wheel when you're bangin gears?
                    just a few to think about.
