Going to the yard to look for drive tran parts, What should I look for and what cars/models.
Rear end, Transmissions, Brakes, etc..
Im in Blaine letting some girl get 14" inches, i think she knows you....
If you think your shit is fast, you'd think my fucking turtle is a time machine.
Our Fearless Leader
Our Fearless Leader
turbo coupe rear end. automatics had 3.55's, 5 speeds had 3.73's
T-Bird Turbo Coupe?
Our Fearless Leader
I was told the Eddie Bower Explorers have 4:10 gears.
What would have a locker or limited slip?
Our Fearless Leader
there is a turbo coupe at U-pull that still had the rear end, but that was about a month ago.
Will that bolt into the Fox body?
Our Fearless Leader
Its a little wider I believe 3/4" If you got huge tire it may or may not be a problem for you but yes it should bolt right up except quad shock I cant remember if they had them or not
f150's had 31 spline differentials usually with a higher gearing. you might be able to find one with 373's or even 410's. usually the higher gearing is in the 4wd trucks
I think its kinda rare to find a truck with a limited slip and anything above 3.55s atleast when I had my f150 these parts where kinda hard to get ahold of but possible
