put a t-5 or t-56 in a 67 mustang?
  • gt289
    • Jan 2007
    • 50
    Since I may be getting the chance to run my step-dad's car next year, I am thinking about making my car a little more dependable on the street. I was looking at either a t-5 or t-56. Just was wondering if anyone has made the conversion, or could give any tips since it would be a new project for me.
    Thanks
  • TRDon
    ......because trackcar
    • 13153
    Dneinstadt has a 66 he put a T5 in. PM him and I bet he has some good advice for ya Cool project, good luck
    Originally posted by Hack
    I disagree.
    • DNeinstadt
      Administrator
      • 12577
      T5! unless you want to "clearance" (read hit with a hammer or cut) your trans tunnel. I have done this conversion and if you pick up all the parts, it's a bolt in deal.
      Dan
      • Fosters
        Typical white person
        • 16014
        i've put a t56 in my car, but it was a bolt in deal. if i had to do it again, i'd do it in a heartbeat. if a T5 is a bolt in though, i'd go with that... they're a dime a dozen and not quite as bad as everyone makes em out to be...
        • gt289
          • Jan 2007
          • 50
          about how much power can you put through a t-5? I'vee heard both good and bad things about them. I am going to go with a little different combination than i got now. But will still be putting over 420 HP at the motor.
          • DNeinstadt
            Administrator
            • 12577
            Get a built one, either a G-force or a regular T5 that has been built for power.
            I'm planning on putting 500+ through mine... eventually.
            • Pauly
              It's Gone!
              • Jun 2007
              • 2870
              just remember there are a couple different t-5's out there. talk to the other guys and make sure you get the right one. theres a t-5 and a tremec 5 that also get called a t-5 I know this because a friend bought what he thought was the bullet proof and ended up with a poodle. Have fun slammin the gears.
              • Roast'em
                has posted this
                • 5496
                T56s are expensive.
                • Racin Repair
                  You wish!
                  • Mar 2005
                  • 2166
                  Put a top-loader 4 spd in you'll never break it! far more reliable than a t-5 or 56.
                  9.10@142 on DOTs thru the mufflers, back when I used to race...
                  • allstock93gt
                    does not visit often!
                    • 1959
                    420 hp at the crank with a good clutch and any sort of traction = the end for a t-5. call or contact tony at http://astroperformance.com/ and see what he recommends. they have a few different levels of t-5s for you.
                    I have a g-force and broke 3rd gear the same problem I was having with the stock t-5s and I put down 360whp and 375wtq.
                    maybe this 1!!!
                    it's almost allstock! except the wheels.
                    • gt289
                      • Jan 2007
                      • 50
                      yeah i have heard that 3rd gear is the problem. thanks for the help,
