check engine light
    check engine light
    i was wondering, my check engine light will sporatically go off, is this because i have no exhaust ? or what else could be causing this ? anyt input would be appreciated.
  • FASTANG
    not really, but someday
    • 1294
    do you still have the EGR Valve hooked up? If you do not than it could possibly be looking for it and not finding it.
    It could be many different things. Is the car doing anything unusal when it is triggered?
    Taryn
    Want to see more? -->'95 GT
      no, i will jsut be driving and it will go on after a while then sometimes when i speed up the light will shut off.
      • FASTANG
        • 1294
        There is still too many variables that could be causing it to pinpoint it from what you've said.
        Anything else you can tell us about it before/while/ right after it happens?
        Taryn
        • #5
          i used to have a similar problem the check engine light would come on at about 1800 rpms then turn off... it did this CONSTANTLY... but when i changed my intake manifold and throtle body it stopped... but i put in all new idle air solenoids and egr valve and sensor...
            hmmm
            it really isnt informing me of crap, i checked evertything over and nothing is loose, is there a plug i can pull to just make it so the light never comes on ? or would this not be a good idea ? its jsut so it stops bugging me.
            • usafracer
              • 237
              Check the voltage reading on you TPS they some times need to be adjusted.
              • oCancerPatiento
                Ive been saved.
                • 377
                My car used to do the same thing. I just took off the egr valve and cleaned out all the carbon with carb cleaner and it hasn't come on since.
                • redv6Lance
                  tcs has-been
                  • 434
                  1 where is the egr valve located, i've never heard of that
                  2 my car does the same thing, and ONLY if i've been driving at around 1800 - 2000 rpms consistantly for awhile, like highway driving. do you think a bad O2 sensor could be the cause of this, cuz i DO have a bad O2 sensor.
                  3 foxbox - why dont you just go have a autoshop check your codes for like 20 - 40 bux.... thats what i did.
                  • MetallicPony
                    • 14093
                    last time my check engine light went on, basically my whole fuel system crapped out on my in the middle of the freeway, you can never be too careful...
                      my dads friend has one of them computer things, so i am going to have him try and see what the deal is, but if that doesnt turn out, i will just clean everything, and such.
                      • jjhirsch
                        hirsch
                        • 3776
                        a few days ago i was on the high way and it turned on so i stoped and pulled over and put it on park turned my lights off and heat and then wile i was about to get out of the car i looked for the light and it was off, it was the first time i have ever seen it on and it has been 5 days and it hasnt done it since
                        it could be the 02 sencer or something
                          Don't know a whole lot about this fuelie bs, but the code should be saved whether it's off or stays on, run an OBDII code scanner or whatever on it and see what it says, orr you can dick with the paper clip trick, could probably find the legend on the internet somewhere.
                          • theduckylittle
                            Duck uber Alles
                            • 5435
                            OKay, okay, okay. STOP GUESSING! The computer tells you what's wrong. All it takes is a little time and a paper clip for it to tell you what's going on...
                            Follow this procedure (not sure where the EEC-tester is located on a Mustang).
                            Now, get the code, AND THEN start worrying about how to fix it. Sounds to me like you may have an O2 sensor that's starting to go out... but that's a shot in the dark if we don't know what the computer think is wrong.
                            -Duck
                            • #15
                              Go to Checker and borrow their code scanner and do it yourself. They might even do it for you if they're not busy. Don't dick around with guessing.
