Removing stripped bolts... need help!
  • SmithEvo
    Poppin' VTAK yo!
    • Nov 2004
    • 25468
    OK, so I've got this bolt on my truck. It uses a flathead to get it on/off. The head is stripped. How do I remove it now?
    Not at the table, Carlos.
    Use a chisel and hammer on the outer edge so it spins out?
    • taank
      • 10278
      if you have room take a die grinder and remake the slot for your screw driver
      Jake H.
      • 96zjlimited
        • 2092
        Is this one of em that holds the injector pump top on??
        • onewickedstang
          umm sure
          • Mar 2007
          • 206
          if there's room you can weld a nut on the top of it and remove it like a regular bolt.
          86 notch: 393W/c4 combo.......best of 10.63 @ 124.98 so far.
          89 notch: the new project
          99 contour: puddle jumper
          • SmithEvo
            Poppin' VTAK yo!
            • Nov 2004
            • 25468
            Nope, its one of the two that hold the fuel plate in. I got it by putting a flathead in that was too big, and tapping it in to force it to fit (like the breakoff screw and a torx bit). Then I put a new one in.
            No welding or grinding. This is inside the injector pump. Guess I should have specified. Thanks though.
              told you those things suck to work on.
                2 beer is right again.
                • SmithEvo
                  Poppin' VTAK yo!
                  • Nov 2004
                  • 25468
                  It would have been cake if some jackass hadn't tried to slide the fucking fuel plate forward, and instead stripping the head of that bolt. They must have tried to pull it off with a fawking screwdriver
                  • black bucket
                    • Nov 2006
                    • 424
                    they make reverse drill bits, they work alright. some times they can bite a little and back the bolt out.
                    :fu2:
                    • OffShore
                      yes it floats
                      • 9995
                      We used to remove key lug nuts by pounding on a socket over it. ( dont ask why JK)
