5 lug fronts
  • SteveR
    • 432
    5 lug fronts
    I picked up spindles, rotors, calipers off a 95 mustang for my 79. The only problem I have is where the spindle bolts up to the struts, the newer spindle is narrower. Can I just shim it with washers or do I need to get 94+ struts?
  • Old Man
    Elder Statesman
    • 5711
    Best to get 87-newer struts.
    www.transport-graphics.com
    www.knowltonsthunderheads.com
    www.dukesraceshop.com
    www.meanstreetperformance.com
    www.fleetwoodcollision.com
    www.idealautoglass.net
    • Steve
      eMechanic
      • 5381
      Shim it. Some struts come with shims just for this reason, old man.
      • SteveR
        • 432
        79-93 carry same P/N. Thanks 92MNstanger!
          Thats news to me. My 86 struts wouldn't bolt up, the holes were in slightly different spots and it was narrower. I had to get 87-93 struts.
          • SteveR
            • 432
            I guess I am just going by what summit says?
            • svonasek
              • 1641
              Some of the struts like lakewood drag struts list themselves as 79-93, but they come with the shims to make the 79-86 spindles work. I have an 83, but used sn95 spindles. I had to use 4 washers per side (2 per bolt). Worked fine, but it was a pain to hold the washers in while I put the bolt through. Also I had to open up the top bolt holes on my struts, but everything I've read said I shouldn't have had to.
                Thats how mine were. I just bought new 87 ones and they fit perfectly now. And it rides way better because the old struts were shot.
                  struts are diff. get some 87-93's.
                  • Odrapnew
                    Everyone likes being blown.
                    • 2880
                    The bolt hole spacing on 79-86 struts is different than on the 87-93 struts(and spindles). Order ones for 87-93 cars just to be safe.
                    And from what I remember, the spindle is a little thinner on the 94+ like the other guys said so you will have to use a few spacers(washers).
                    • svonasek
                      • 1641
                      You won't need shims if you use the 87-93. Should just bolt right on.
                      Oh yeah, if I was doing it again...sn95 balljoints (non-extended version), bump steer kit and caster/camber plates all at one time.
