say your using good axels 33 or 35 spline, spool, and good gears. 500? 750? 250? -134?
how much power can a 8.8 handle?
i dont think ive ever read or spoken with anyone who actually cracked a housing. lots of axles and carriers but never an actual housing.... make sure to weld the tube on...
Mine has been "upgraded" by Richard at Mean Street Performance. 33 spline axles, spool, diff cover with support that goes out to axle tubes, welded tubes, straightened, 9" ends welded on with the big bearings, 5/8 axle studs (over-kill but they look cool), leaving on a trans-brake with a 250 shot out of the hole is the goal and I'm not concerned about the rear-end in any way.8.54 @ 159 mph on a 275 drag radial
Originally posted by Modded Mystic View PostNick are you going to have it ready by MCSO?
~Mark
intake got screwed up so he's porting another one. Hopefully have the heads, intake, cam, timing chain early next week. As soon as the intake gets here I'm going to send it off to get plumbed for the fogger. I probably won't even have the engine dyno'd by then.
:insert curse words here: I guess there's always next year!
I here the curse words Nick, and i know how ya feel!!!Originally posted by Ford Fan View Post
Looks good for 08 I guess, 07 Here to drink beer.
33splines weaksauceOriginally posted by Ford Fan View PostMine has been "upgraded" by Richard at Mean Street Performance. 33 spline axles, spool, diff cover with support that goes out to axle tubes, welded tubes, straightened, 9" ends welded on with the big bearings, 5/8 axle studs (over-kill but they look cool), leaving on a trans-brake with a 250 shot out of the hole is the goal and I'm not concerned about the rear-end in any way.
35'S BITCH
, WELDED , STRAIGHTNED, GIRDLE AND 5/8" STUDS ALSO . I think I have over kill too!
