'bucking' from a car w/a manual tranny
This topic is closed.
    What would cause a car to, for the lack of a better workd - 'buck' while driving it. It can be real jerky at times. A guy can sort of learn to make the best of it and drive differently to lessen the effect... but it can still be irritating. Would the clutch be suspect?
    too low of a rpm?
    • OffShore
      yes it floats
      • 9995
      My car did it w a bigger cam and only at low rpm, fixed it w a tune and 90% of it is gone.
        random cyl. missfire? clutch out or in.... speed... could be a warped flywheel.
        • 86dcbra
          • 885
          Air coming in after the mass air meter would also do it or vacuum leaks
          86 Sold
            What kind of car? More specific about when it happens, please.
            Is it more of a chatter when engaging the clutch or just constant RPM not touching the clutch and it is 'bucking'? Under heavy load or no? Hot or cold?
            • Mullet Tuner
              • 15906
              Modifications to said vehicle? What make, model, and year is it?
              Originally posted by Gerald
              • Xtort
                • 6968
                My car does that in low rpm ever since I got my cams.. I'm going to get gears at some point here to remedy the situation.
                http://youtu.be/GTQnarzmTOc
                  When mine does it the wide band reads pretty rich.
                    ... mods? Off-road exhaust (i.e. no cat-convert), K&N filter. It's a '93 Cavy
                    It does it when clutch is engaged at speed in either 3rd of 4th, not touching the clutch. Sometimes it'll do it in 4th bad enough that it makes me downshift to 3rd to get the Rs' back up (which it does NOT like to go down to 3rd), and that'll help a bit... but it'll still do it somewhat. I'm not sure if it matters when it's cold or hot... but if I had to pick one over the other, I'd say when it's operating temp. So no cam swaps... no real mods... just a high mileaged beater that I'm wondering if something can be figured out/fixed somewhat cheaply. I know it's a reach, but what the hell
                      Does it stop when you just push the clutch and not downshift? Are you trying to accel in 4th when it happens or is it just casual driving partial throttle?
                        losing any coolant?
                          Yeah, it stops if the clutch pedal is pushed in, weather I downshift or not. It'll happen in 4th a lot for sure... maybe not so much as accerating to 5th so much as just trying to keep it in 4th and drive around in that gear. It seems to take issue with it sometimes. Sometimes in 3rd too... but more often in 4th I think. So maybe casual driving I guess, partial throttle.
                            Originally posted by 2 beer View Post
                            losing any coolant?
                            Not that I'm aware of, no. Headgasket was done just before I bought it a few years ago. Once in a great while I might get the slightest hint of antifreeze... but it's hard to tell really. Could be from the heater core for all I know, as the aftermarket ones don't seem to last that long really.
                            • Hack
                              • 1415
                              How long since it's had a tune up (plugs, wires, etc)?
                              2017 Mustang GT PP
                              1986 Porsche 944
