I want to make my car faster...
  • chicostang95
    • 1076
    its buying a new engine the only solution?? a 347? because the miles on my car are pretty high. i want to spend under 4 or 5K any suggestions?
    Heads, cam, intake, exhaust, bolt-ons, gears. A 347 will cost you more than 4-5k when said and done.
      His car has high miles.
      Which means it needs a rebuild to begin with...
        Sell your car, Spend that money + a couple k and buy the 347 Stroked 94 blue car in the classifieds..
        • 98Julik
          • Mar 2007
          • 2614
          That car is sweet, It drives like a charm
          It's like watching a fat girl in stretch pants and a thong dancing. Sooner or later, something is going to happen, it might not be pretty, but you can't help watching
            Ok. Well either way with 4-5k you still really can't do a 347. New bearings, rings and seals on the 302 along with H/C/I is still going cut it close to keep within the 4-5k budget.
            • DNeinstadt
              Administrator
              • 12578
              LOL at the off topic posting in this thread.
              • KrisR
                KNT-SHO
                • 12737
                Not necessarily. Depends on how 'high' the miles are. For example, Macs Stang's stock 302 had over 170k on it and from what I understand it was nearly perfect when it was torn apart, and it had A LOT of nitrous go through it. It was only replaced because he got a deal on a complete 327 setup.
                If its using oil or has low compression, then yes, a new rotating assembly might be in order.
                • chicostang95
                  • 1076
                  thank you guys for all the answers but hightech told me for a new 347 i would b spending around 5k.. so i wasnt sure if it was worth it or not,,
                  • waterbug1999
                    Got Beer?
                    • 3554
                    Then add the $$ for a new trans and a rear end, I am sure that will go next with the extra HP..
                    1999 Trans Am
                    10.71@126.9 / stock shortblock
                    • StangerJon
                      esse jay
                      • 16655
                      why would you need more then an 8.8" rear end for something with 300-350hp?
                      seems like his street tires would break loose before his rear end exploded.
                      • waterbug1999
                        Got Beer?
                        • 3554
                        True, but if he goes to the track, that will be a different story.
                        1999 Trans Am
                        • 289Notch
                          Lowballer
                          • 7340
                          sure with stock top end and cast crank you could build a 347 for much cheaper than 5K. It's all in the parts. stuff like milidon pan and windage etc. $500. heads $1500 good rot assembly vs cast, Ibeams,hypertecht .
                          Some people will probably disagree, but if you got your hands on some stock cleavland heads and rebuilt them with porting and put them on a 400+ cube cast crank I beam rodded cleavor. It would be very fast even with a little hydraulic cam and could be done for $5K. Headers might get ya though.
                          Mustangless!
                            5k for a long block 347 is fair. But like others have said, you will need other things. Such as a better clutch your rear end wont hold together forever, a better fuel system, will probably want a better ignition system there are more things but that right there with you doing the work is an easy 1500-2000 worth of parts.
                            • 289Notch
                              Lowballer
                              • 7340
                              I just talked to a friend today that built a 427 windsor for his shelby. He paid $1500 less than I did for my 347. He made 20 more HP and more torque across the board. But the killer is that he has a hydraulic cam and he revs his motor 1000 RPMs less than I have to while idling much better as well.
                              If I had to do it over again I'd have went with a tall deck sbf stroker.
                              Mustangless!
