I replaced a head on my 95 Gt with a P1SC Procharger. I used new head bolts(FelPro)when I re-assembled and followed their torque specs. A short time later I blew the head gasket. I believe the torque spec was 55ft. lbs. and a quarter turn. I am not sure why the gasket let go, I am only pushing 8 lbs. of boost, and the other head is working just fine. When I removed the head from the block, I noticed it didnt take much effort to break them loose. When I removed the original head, it took ALOT more effort to break them. Should I torque them higher, or do something different? Thanks
Torque to Yield Head Bolts
Almost anything and everything I've read for bolting heads onto a 302 state that the top head bolts should be dipped in motor oil (i.e. 10w-40) and ultimately torqued to 80ft/lbs, and the bottom head bolts should have thread sealer on them and ultimately get torqued to 75ft/lbs.Originally posted by NickThe choice is easy.
Originally posted by Stormwalker View PostAlmost anything and everything I've read for bolting heads onto a 302 state that the top head bolts should be dipped in motor oil (i.e. 10w-40) and ultimately torqued to 80ft/lbs, and the bottom head bolts should have thread sealer on them and ultimately get torqued to 75ft/lbs../ ____ _ _\.
That is if you still have 3/8" head bolts. MY 1/2" studs are 80# lower and 90# upper. And that is for studs with nuts not bolts , so I will shut up now as it doesnt apply .. As you were.It is a damn poor mind indeed which can't think of at least two ways to spell any word.
Originally posted by LES View PostThat is if you still have 3/8" head bolts. MY 1/2" studs are 80# lower and 90# upper. And that is for studs with nuts not bolts , so I will shut up now as it doesnt apply .. As you were.86 notch: 393W/c4 combo.......best of 10.63 @ 124.98 so far.
89 notch: the new project
99 contour: puddle jumper
Originally posted by onewickedstang View Postnot that it matters to this post, but Edelbrock recommended dropping 10# when using the 1/2" studs due to the extra clamping force provided by the studs and fine threads. when my motor was assembled the shop that did the assmebly tightened them to the 105# that fel-pro had listed on the install sheet for the gaskets. they ended up cracking the water jacket on both heads near the lower studs. they did however take credit for the mistake and pay to have them welded.
1) 105# is 15% more then 90# And is incredible THAT ANY ENGINE BUILDER WOULD DO THAT!
2) My TFS TW heads are ALOT thicker thne Edelbrock.
But I do hear what you are saying.It is a damn poor mind indeed which can't think of at least two ways to spell any word.
Originally posted by SouthernLX View PostYou are correct. Not sure where 55 came from?Still use the moly-lube on the underside of the bolts.....7/16th of an inch bolts BTW.
Torque-to-yield head bolts are factory type replacements and are supposed to stretch when torqued, unlike ARP bolts or studs.....Last edited by mustang cobra93; 06-25-2007, 06:41 PM."The power of the RIFF compells me"
"Champipple"
I put the head back on tonight. Thanks for all the opinions and advisement! I ended up torqing them to 70#. When I took the head off it was obvious the gasket let go on the top edge near the lifter valley and the water escaped there. There were 3 definitive areas leading from the water jacket holes in the gasket right up to the lifter valley. Hopefully the 70# torque wont be an issue.
Thanks again!
