03 Cobra steering column ?
  • orangefox
    • 1603
    How does that exterior ignition cylinder piece come off so that you can get the upper steering column cover off?
    2002 Ford Excursion
    2003 Ford Expedition
    2005 Mercury Mariner
    80' Buick Regal drag car
    88' LX Mustang 5.0
    2010 Yamaha Road Star
  • Video_Master
    Kickin it Hybrid Style
    • 10524
    dang, how come you are disecting the steering column?
    • DNeinstadt
      Administrator
      • 12578
      Yeah, the gauge pod goes OVER the column..
      • Grenade
        • Mar 2005
        • 3659
        He's prolly adding a gauge or something.
        • Video_Master
          • 10524
          Ahh, most likely for the new gauge. Yup just like D9 said it goes over the factory top of the column. Very easy to mount.
          • EFI Performance
            EFI is back!
            • Dec 2005
            • 636
            Removed the lower cover, install the ignition key and turn to engine run, from under the col there is a 1/8 in hole and pin for the clynder, push in the pin and pull the lock set out at same time. Then the upper peice can be removed.
            Good luck...
            • orangefox
              • 1603
              Yep, installing new guage pod. Want to take it apart though so I can route the wires nicely and fit the two pieces together.
              2002 Ford Excursion
              88' LX Mustang 5.0
              • orangefox
                • 1603
                Good luck...
                Thanks
                2002 Ford Excursion
                88' LX Mustang 5.0
