I have blown 2 sets of head gaskets on my 302 and I know the heads are good and the block is good. (not warped) I am just wondering if there is a better gasket that works well with forced induction. AKA 200 shot of giggle gas.
head gaskets
your choices would be 1) mls head gasket. keep in mind mls gaskets require a very flat and smooth finish on the heads and block. 2) back off the blow to a safer 150. if the car hasen't beed tuned on the juice that would be a good start. a lean condition would cause detination and cause a head gasket to go pop or with beter head gaskets to piston, bearing, rod, ect issues.
This is just personal experince
347 12.7-1 comp
TFS TW heads
200 shot on a plate kit
255 intank pump
ROL extreme HG's
ARP studs
Cooked 3 plugs but never blew a HG
Pulled motor running and inspected heads and pistons looked good. Rings where toast and the valve seats took a beating but it was fun.
10.40's @ 126 with a AOD.
I would check the tune and A/F plus make sure you have enough fuel pump.
Mine was done on the big end and thats what killed 3 plugs.
Fine on the dyno but could handle the volume for a 10 second pass.
Also have you had the heads deck since you blew the HG or have you had the block check to see if its still flat.Progress. Should be fun.
sigpic
